Door handles |
Door handles |
Kansas 914 |
Jun 30 2015, 05:00 PM
I took some pictures and I will post when I can get them of the camera. The chrome is shiny but I could see slight waves. Fit was good but time will tell if the casting can stand up to the rigors of use. |
Larmo63 |
Jun 30 2015, 05:09 PM
Yes, the door panel has to be taken off to get to the allen head. It is a 5mm if i remember correctly. That takes longer than the R & R of the handle. While you're in there, take out the door latch mechanism and clean/degrease it and re-oil/grease. You will be happy you did and the handle & slider will last you a whole lot longer.
Kansas 914 |
Jun 30 2015, 05:21 PM
I took some pictures and I will post when I can get them of the camera. The chrome is shiny but I could see slight waves. Fit was good but time will tell if the casting can stand up to the rigors of use. I just realized this laptop has an SD reader so here are 2 pictures. If there is a particular image you want I will take it. |
Kansas 914 |
Jun 30 2015, 05:26 PM
Yes, the door panel has to be taken off to get to the allen head. It is a 5mm if i remember correctly. That takes longer than the R & R of the handle. While you're in there, take out the mechanism and clean/degrease it and re-oil/grease. You will be happy you did and the handle & slider will last you a whole lot longer. (IMG:style_emoticons/default/agree.gif) There are many points of friction in that mechanism it is amazing that it ever worked. Keep it oiled/greased. Door handles would last a lot longer if this mechanism was maintained. |
URY914 |
Jun 30 2015, 05:40 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,147 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
So these are EXACT copies of the original?
No effort was made to correct some of the weak points of the original design? Why the big gap in the joint of the new one? |
Kansas 914 |
Jun 30 2015, 07:21 PM
So these are EXACT copies of the original? No effort was made to correct some of the weak points of the original design? Why the big gap in the joint of the new one? Hi Paul, No one knows these handles better than you. I think the "gap" is the way the light was hitting the bevel on the handle. Let me compare and take more pictures. |
sb914 |
Jul 1 2015, 08:16 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
They seem to be nice,haven't installed yet
time will tell. |
URY914 |
Jul 1 2015, 10:38 AM
One of the problems with the previous reproductions was the size of the body side of the handle. When I say the "body side" I mean the body being the piece with the lock cylinder in it. On those it didn't line up with the "flapper" or the part you pull to release the handle.
echocanyons |
Jul 1 2015, 01:06 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Looks like the sale ended yesterday.
If you anyone is interested they may be able to retroactivate the sale price today. |
Lo-Fi Version | Time is now: 25th April 2024 - 11:45 AM |
