Rear Brakes for the race car |
stugray |
Jun 28 2015, 12:51 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I posted this in the paddock, but didnt get much traffic over there.
I have three calipers ready to put back together on my bench and I am waiting to make the decision based on this question below. Anyone here ever modified their calipers by breaking out the knock back pins? As usual Eric's site has the most information regarding these pins, but he doesnt go into detail about the possible benefits of doing so. I was hoping to hear from at least one other racer that has done this, why, and what were the results? And.... just to confirm: it is the late front calipers that fit the rears , correct? (I have measured, but not test fit them yet) Based on some advice from other racers, I am installing some front calipers on the rear of the race car. Currently I have stock front calipers, stock rears, and a 19mm MC, and still have the stock rear prop valve. I have a few sets of late front calipers that I disassembled to rebuild for this change. One of the calipers had the pins for the knock back mechanism broken out by some previous owner. I understand that the newer A-calipers do not have this mechanism from the factory. How many others here have done the front caliper installation on the rear? Did you keep the rear prop valve, or go for an aftermarket like the tiltons? Has anyone heard of breaking out the knock back pin? If so, what advantage is this supposed to provide? Should I use calipers with the knock back system intact, or should I break the pins out of another caliper so I have a matched set? I plan on running KFP Gold pads on the front and Porterfield AP31T R4-S pads on the rear for some front bias. Any more tips or tricks ? |
SLITS |
Jun 28 2015, 03:43 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Not Porsche, but Datsun (NOT NISSAN). The front calipers had knock back pins. On the race cars, we broke the pins out to make sure the pads "retracted" away from the rotors due to the intense heat generated in SCCA racing. Can't say that it was an approved method, but several Regional and a few National Championships said we didn't do anything wrong.
We started pulling the pins after a race at Firebird in Arizona. When the front brakes caught on fire due to fluid boil and distended piston seals we figured we had to do something. Yes, we had brake cooling ducts to the front calipers/rotors. Ever tried to find caliper seals on a Sunday? Ran the race with rear brakes only as I had plugged off the front calipers. G Production - 2 car team |
Lo-Fi Version | Time is now: 26th May 2024 - 09:58 AM |
