Engine Stalls, Engine stalls and dies out when I begin to release clutch |
mimatti |
Jun 29 2015, 06:02 AM
Newbie Group: Members Posts: 5 Joined: 29-June 15 From: Michigan Member No.: 18,896 Region Association: Upper MidWest |
Hello to all the 914 owners,
I am new to this forum and it looks like a great place to be regarding 914's. A little background about my 914 before I ask my question. It's a 1972 1.7Liter, that had it's two carburetor system replaced, in 2011, with a brand new single Webber Carb. I bought the car 4 years ago and unfortunately it's been sitting in my garage ever since due to various projects. I was able to drive it up the drive way and into my garage with no isuues, and she stayed there the entire four years. This weekend I decided to take it out and drive it a little. The idle was way too low, so I adjusted and got the idle to just under 1,000 rpm. The problem is when I try to start out in 1st gear, as I begin to slowly release the clutch, the engine's power dies to the point where the engines dies out. Even when I revved the engine to almost 3,000 rpm and then slowly released the clutch, about mid-way in the clutch's pedal travel, the engine's power is robbed, engine rpm goes down toward idle very quickly, and the engine dies out. I made sure that I was in 1st gear and not a higher gear, the problem persisted to the point where I couldn't even drive it back in my garage, I had to push it in. Before I remove the carburetor, or and clutch work, does anyone have any idea of what the problem might be, or at least limit the possibilities to a system, i.e. fuel, air, carb, clutch, etc... I appreciate any help in this matter because I now finally have the time for this Porsche and want to begin enjoying it. Regards, mimatti |
914Mels |
Jun 29 2015, 02:17 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
If your clutch is slipping, it wouldn't make your engine die out, your engine would rev and the car wouldn't move like it should. Really sounds like a clogged up fuel system or a really plugged up air filter.
Lo-Fi Version | Time is now: 24th May 2024 - 02:21 PM |
