Engine Stalls, Engine stalls and dies out when I begin to release clutch |
mimatti |
Jun 29 2015, 06:02 AM
Newbie Group: Members Posts: 5 Joined: 29-June 15 From: Michigan Member No.: 18,896 Region Association: Upper MidWest |
Hello to all the 914 owners,
I am new to this forum and it looks like a great place to be regarding 914's. A little background about my 914 before I ask my question. It's a 1972 1.7Liter, that had it's two carburetor system replaced, in 2011, with a brand new single Webber Carb. I bought the car 4 years ago and unfortunately it's been sitting in my garage ever since due to various projects. I was able to drive it up the drive way and into my garage with no isuues, and she stayed there the entire four years. This weekend I decided to take it out and drive it a little. The idle was way too low, so I adjusted and got the idle to just under 1,000 rpm. The problem is when I try to start out in 1st gear, as I begin to slowly release the clutch, the engine's power dies to the point where the engines dies out. Even when I revved the engine to almost 3,000 rpm and then slowly released the clutch, about mid-way in the clutch's pedal travel, the engine's power is robbed, engine rpm goes down toward idle very quickly, and the engine dies out. I made sure that I was in 1st gear and not a higher gear, the problem persisted to the point where I couldn't even drive it back in my garage, I had to push it in. Before I remove the carburetor, or and clutch work, does anyone have any idea of what the problem might be, or at least limit the possibilities to a system, i.e. fuel, air, carb, clutch, etc... I appreciate any help in this matter because I now finally have the time for this Porsche and want to begin enjoying it. Regards, mimatti |
mimatti |
Jun 29 2015, 02:21 PM
That's exactly what I nned to know, is to narrow this issue down to a system or sub-system of the car, rather than just start pulling and replacing things on the car. I even removed the air filter and it still did the same thing, so I'm going to start chasing the fuel issue, as to why the engine is not getting the amount of fuel needed when there's a load on it.
Lo-Fi Version | Time is now: 18th May 2024 - 10:50 AM |
