Door panel cage nut, 5mm or 6mm |
Kansas 914 |
Jun 29 2015, 05:33 PM
I did some searching and got differing results.
Is the cage nut in the door 5mm or 6mm. Thanks in advance - cheers! |
Mike Bellis |
Jun 29 2015, 06:54 PM
I did some searching and got differing results. Is the cage nut in the door 5mm or 6mm. Thanks in advance - cheers! What's a cage nut? (IMG:style_emoticons/default/confused24.gif) |
markb |
Jun 29 2015, 07:03 PM
I did some searching and got differing results. Is the cage nut in the door 5mm or 6mm. Thanks in advance - cheers! What's a cage nut? (IMG:style_emoticons/default/confused24.gif) A nut with a cage around it. (IMG:style_emoticons/default/biggrin.gif) |
ejm |
Jun 29 2015, 07:10 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,689 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The arm rest/door pocket ones are 5mm
Kansas 914 |
Jun 29 2015, 08:00 PM
cary |
Jun 29 2015, 08:45 PM
Delete
jim_hoyland |
Jun 29 2015, 09:16 PM
Get that VIN ? Group: Members Posts: 9,258 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
ejm |
Jun 30 2015, 04:31 AM
Mikey914 |
Jun 30 2015, 07:34 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
6mm,
have them in stock $1.88 each, just haven't listed yet. Let me know if you need some. Mark |
Jun 30 2015, 08:54 AM
Yeah, I am pretty sure the ones in the door are M6 as well. At least, I don't remember having to buy a different box of Allen-head bolts when I replaced the fasteners.
--DD |
Kansas 914 |
Jun 30 2015, 01:40 PM
Yeah, I am pretty sure the ones in the door are M6 as well. --DD Now I am confused again. (IMG:style_emoticons/default/confused24.gif) |
Kansas 914 |
Jun 30 2015, 04:56 PM
OK - I am no longer confused.
I knocked one of the original cage (captive) nuts out of my early '72 door. It is an unmolested car that I have owned since 1978 (2nd owner). I took it to the hardware store 2 blocks away to use their nut/bolt gauge and it is indeed an M5. Definitely not M6. BTW - a SAE 10-32 worked as well but was a little loose. Keep in mind that my car is an early MY72 and a lot of things changed that year. It could be that they went to M6 at some point. |
Jun 30 2015, 06:42 PM
Yeah, I am pretty sure the ones in the door are M6 as well. --DD Now I am confused again. (IMG:style_emoticons/default/confused24.gif) Perhaps you were thinking of the tool required to remove the screws? It may very well be a 5mm Allen wrench (hex key), but the threaded part of the bolt is 6mm. So it's an M6 screw. --DD |
Kansas 914 |
Jul 1 2015, 10:05 AM
Perhaps you were thinking of the tool required to remove the screws? It may very well be a 5mm Allen wrench (hex key), but the threaded part of the bolt is 6mm. So it's an M6 screw. --DD DD, The cage nut will not thread on to a 6mm bolt at the hardware store. It will thread onto a 5mm. |
cary |
Dec 12 2015, 07:20 AM
M5 * .80 pitch
Looks to be fairly common. Used on computer server racks. I think I'll buy a bag of 50 for $18. Keep 10 and get the other 40 over to Mark at 914Rubber. |
cary |
Dec 12 2015, 07:37 AM
http://ospmk.lqhac.servertrust.com/v/vspfi...age_fr_back.pdf
Found this in my searching. I'm thinking soft HF screwdriver and bend the tip without snapping it off. |
Kansas 914 |
Dec 12 2015, 10:07 AM
M5 * .80 pitch Looks to be fairly common. Used on computer server racks. I think I'll buy a bag of 50 for $18. Keep 10 and get the other 40 over to Mark at 914Rubber. (IMG:style_emoticons/default/beerchug.gif) |
cary |
Dec 12 2015, 09:23 PM
Stopped by Ace Hardware, they only carry 6mm *1.0.
Larry.Hubby |
Dec 12 2015, 10:03 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
If you look at PET, main group 8, sub-group 7, illustration 807-05, items 11 and 19 are definitely called out as 5mm screws. Granted, it's difficult to tell exactly where these screws go from the illustrations in PET, there is, however, no 6mm hardware specified anywhere in this sub-group, which includes the door panels and arm rests.
It's hard to tell the difference between 5 and 6mm hardware sometimes. The one that drove me nuts for a long time was the nut that secures the strap that holds in the glove box. I kept finding it loose and tightening it up, only to find it loose again in a short time. Turns out, it's a 5mm stud and a 6mm nut will go on and even tighten, up to a point. But a little more force will cause the nut to jump a thread or two, loosening the strap again. I finally replaced the stud with a 6mm one. |
cary |
Dec 22 2015, 11:20 AM
Lo-Fi Version | Time is now: 23rd April 2024 - 02:45 AM |
