1 Wet spark plug., One wet one dry???? |
catsltd |
Jun 30 2015, 06:52 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
I wanted to check out my spark plug after a short drive since car does not have a lot of power above 3rd gear.
The front passenger side plug was clean and dry. The plug towards the trunk(hard to get at plug was covered in unburnt fuel soaked. Any suggestions would really help. Thanks. |
stugray |
Jun 30 2015, 07:09 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Check - Plug wires, rotor, cap.
Sounds like that cyl is not getting spark, but the other one is. |
catsltd |
Jun 30 2015, 07:56 AM
Check - Plug wires, rotor, cap. Sounds like that cyl is not getting spark, but the other one is. For sure its not getting a spark. I bought a new Flame Thrower coil. I also bought Magnecor plug wires and electronic ignition as well. But I need to know what type of plug I should order with this setup???????????. I also dont have a clue as to what is causing the fouled plug,it is gas not oil??????? Thanks Grant. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:05 PM |
