Rotisserie Alternatives, Looking for options |
JoeDees |
Jun 30 2015, 09:05 PM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
I've concluded that I need to replace significant portions of the lower wheelhouse, inner long, and the suspension console. I've spent the day researching and reading the classic threads and like many of the rack-like assemblies my predecessors have built. Let's hear some easy but still effective ways to get this thing off the ground and straight enough for structural repairs.
I really like the one for "Bringing out your Dead" but can't quite figure out the points it's mounted. After bracing the doors, can I use the front jack points, a long support along the floors, the outer suspension console, and the trans mount area? I ready for some ideas. I'm trying to develop as many COAs (Courses of Action) as possible. Thanks. |
914forme |
Mar 3 2020, 06:24 PM
Interesting, only issue I see is that is all thread, it would take forever to raise and lower it. Your thread pitch will determine the speed. Also technically it is the wrong thread design for the job. jacks use a square cut gear for lifting and lowering. pitched thread is good for clamping. But hey it will work.
The one I built uses a welded nut on the end of the winch handles. You can stick a socket on the end of a drill, and it will be at the top, in a minute. |
nathanxnathan |
Mar 3 2020, 06:32 PM
Member Group: Members Posts: 277 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
Interesting, only issue I see is that is all thread, it would take forever to raise and lower it. Your thread pitch will determine the speed. Also technically it is the wrong thread design for the job. jacks use a square cut gear for lifting and lowering. pitched thread is good for clamping. But hey it will work. The one I built uses a welded nut on the end of the winch handles. You can stick a socket on the end of a drill, and it will be at the top, in a minute. Yeah acme thread would be better for sure |
Lo-Fi Version | Time is now: 11th May 2024 - 08:40 PM |
