how to remove, Questions while parting a 914 |
914outlaw |
Jul 1 2015, 06:12 PM
Dave Group: Members Posts: 198 Joined: 2-June 10 From: Central, NJ Member No.: 11,800 Region Association: North East States |
I decided to cut up my parts car and I'm trying to save some things as I go.
First question is how do i remove without damaging the side pads that the seat belts screw into? I took off the belt and a single screw. Does the clothes hook have to come out? Thanks Dave |
Porsche930dude |
Jul 1 2015, 06:39 PM
Member Group: Members Posts: 399 Joined: 25-November 11 From: Vestal NY Member No.: 13,819 Region Association: None |
yes the plastic cover that is the clothes hook slides up and out to reveal a metal bracket with screw
914outlaw |
Jul 1 2015, 06:58 PM
Maltese Falcon |
Jul 2 2015, 10:10 AM
Advanced Member Group: Members Posts: 4,637 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
If you are able to cut out this cowl piece, or just cut one good w/wiper round piece out of the sheet metal...that's what I'm looking for. Just leave as much sheet metal around this round shape as possible.
PM me with your price (IMG:style_emoticons/default/sawzall-smiley.gif) Thanks Dave |
914outlaw |
Aug 6 2015, 08:47 AM
If you are able to cut out this cowl piece, or just cut one good w/wiper round piece out of the sheet metal...that's what I'm looking for. Just leave as much sheet metal around this round shape as possible. PM me with your price (IMG:style_emoticons/default/sawzall-smiley.gif) Thanks Dave I haven't reached that part of the car yet. I'll let you know. |
914outlaw |
Aug 6 2015, 08:50 AM
Another dumb question.
How do you remove the trailing arms. I've taken off the two nuts from each side of the shaft. Does the bolt shaft slide out? The car is practically laying flat on the ground so I can't see if there is something else to remove. |
madmax914 |
Aug 6 2015, 09:06 AM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
Another dumb question. How do you remove the trailing arms. I've taken off the two nuts from each side of the shaft. Does the bolt shaft slide out? The car is practically laying flat on the ground so I can't see if there is something else to remove. Remove the Trailing arm support bracket, it's on the outboard side of each trailing arm. There are three bolts per bracket(I think they are 10mm bolts). You may find shims under the bolts or the bracket, keep those if they have not rusted beyond useful. |
rgalla9146 |
Aug 6 2015, 09:08 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
You're going to have to lift the car. Then you will be able to get to three bolts on each outside mount. They are accessed from below, inside the outer mount. 17mm bolt socket
914outlaw |
Aug 6 2015, 09:20 AM
Lo-Fi Version | Time is now: 5th May 2024 - 09:15 PM |
