Transmission mount options |
john77 |
Jul 1 2015, 11:24 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I need to replace the bushings on my transmission mounts, but after doing a little research I realize, as usual, there are more options than my tiny mind can handle. The car is an AX/street car that I'm slowly modifying with AX in mind.
So far I've found what appear to be a couple of stock replacements at AA: http://www.autoatlanta.com/Porsche-Transmi...1437502500.html Semi-solid mounts from WEVO: http://www.wevo.com/Products/ChassisProduc...TransMounts.htm And solid mounts from Patrick Motorsports: http://www.patrickmotorsports.com/part/914...sion-mount-set/ Anyone have any experience with any of these? Other suggestions? The car will still be used on the street, so am I right in guessing solid mounts might not be the best option? Thanks John |
GeorgeRud |
Jul 2 2015, 07:00 AM
The stock mounts should work fine. In my conversion car with a large -6 and a 915 transmission, I went with the WEVO mounts to try to help with shifting (minimize any movement at the transmission), and have been very happy with them. Whether they are worth the increased cost is up to you, but I think they're a great alternative.
Lo-Fi Version | Time is now: 19th May 2024 - 05:25 AM |
