Transmission mount options |
john77 |
Jul 1 2015, 11:24 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I need to replace the bushings on my transmission mounts, but after doing a little research I realize, as usual, there are more options than my tiny mind can handle. The car is an AX/street car that I'm slowly modifying with AX in mind.
So far I've found what appear to be a couple of stock replacements at AA: http://www.autoatlanta.com/Porsche-Transmi...1437502500.html Semi-solid mounts from WEVO: http://www.wevo.com/Products/ChassisProduc...TransMounts.htm And solid mounts from Patrick Motorsports: http://www.patrickmotorsports.com/part/914...sion-mount-set/ Anyone have any experience with any of these? Other suggestions? The car will still be used on the street, so am I right in guessing solid mounts might not be the best option? Thanks John |
DRPHIL914 |
Jul 2 2015, 08:33 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I've used Porsche 911 "sport mounts" since I bought the car. They're the same dimensions as normal 911 mounts but are stiffer rubber. They were used on Cabriolets circa 1984 - 89 as well... maybe earlier, I never looked into all of the applications.
(IMG:style_emoticons/default/agree.gif) i have the 911 sport mounts for past 2 years, work fine. look here---- http://www.pelicanparts.com/catalog/shopca..._UP9144_pg9.htm |
Lo-Fi Version | Time is now: 19th May 2024 - 04:30 AM |
