Transmission mount options |
john77 |
Jul 1 2015, 11:24 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I need to replace the bushings on my transmission mounts, but after doing a little research I realize, as usual, there are more options than my tiny mind can handle. The car is an AX/street car that I'm slowly modifying with AX in mind.
So far I've found what appear to be a couple of stock replacements at AA: http://www.autoatlanta.com/Porsche-Transmi...1437502500.html Semi-solid mounts from WEVO: http://www.wevo.com/Products/ChassisProduc...TransMounts.htm And solid mounts from Patrick Motorsports: http://www.patrickmotorsports.com/part/914...sion-mount-set/ Anyone have any experience with any of these? Other suggestions? The car will still be used on the street, so am I right in guessing solid mounts might not be the best option? Thanks John |
Dave_Darling |
Jul 2 2015, 08:48 AM
There are better places to get things than from AA. That being "pretty much anywhere".
The sport mounts are pretty good for street cars. A bit stiffer, but they still keep the NVH (Noise, Vibration, and Harshness) down. You may have to tweak the mounting points on the chassis just a little bit to make them fit nicely, but that's not a big problem. --DD |
Lo-Fi Version | Time is now: 27th May 2024 - 11:17 PM |
