Clutch cable, .......I think |
porsche-tom |
Jul 3 2015, 08:32 AM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
so i just started my car and got about 2 blocks and when i depressed my clutch pedal I felt a pop and it went all the way to the floor. But if i put it to the floor i can still shift into different gears. as soon as i take it off the floor i wants to go. i would assume its the cable but its just odd that i can still shift...... sort of... ideas? tips?
cary |
Jul 3 2015, 08:38 AM
The cable tube came disconnected from the tunnel.
kkid |
Jul 3 2015, 08:40 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
it sounds like the broken clutch tube.
find a welder near you. |
EdwardBlume |
Jul 3 2015, 08:46 AM
What a bummer. Not the problem you want. Good luck with the repair!
porsche-tom |
Jul 3 2015, 08:55 AM
i have a welder. where might i find the clutch tube???
bandjoey |
Jul 3 2015, 08:57 AM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
The temp repair is a U bolt around the tube and through the side wall of the tunnel. Search here and you'll find pictures to guide you about what's happening.
cary |
Jul 3 2015, 09:13 AM
Bottom tube is the clutch. You'll just slip a u-bolt over the whole thing. The studs will stick out of the tunnel. But pick up some thin jam nuts to replace the ones that come with the u-bolt. Then cut off the excess threads. Cover it up with your carpet and forget about in a couple months.
luskesq |
Jul 3 2015, 09:17 AM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Confirm first that the cable is still intact and if so, as others noted the tube is broken loose. The following site has some decent pics and IIRRCC a link to another repair: http://www.914world.com/bbs2/index.php?showtopic=79938
If one of the welds has broken loose there is a good chance that one of the others is on the verge so check them also. Good luck, Keith |
porsche-tom |
Jul 3 2015, 09:20 AM
Its hard to tell from the pictures. This is in between the seats under the carpet?
bandjoey |
Jul 3 2015, 09:33 AM
Yes. Pull up the tunnel carpet. Open two inspection plates. Flashlight and mirror to look inside.
JeffBowlsby |
Jul 3 2015, 09:36 AM
914 Wiring Harnesses Group: Members Posts: 8,470 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Don't cut the tunnel! Don't use the Ubolt!
Pull the shift lever out and you have all the access needed. temporarily clamp the clutch tube to the side of the center tunnel. Just a couple of strategically located plug welds holding the clutch tube to the side of the tunnel will do it. Simple, quick, permanent and not a hack job. Attached image(s) |
theleschyouknow |
Jul 3 2015, 10:03 AM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
had a similar experience recently -turned out the clevis that attaches the cable to the pedal broke not the cable itself
don't know if it would still shift or not I didn't try it good luck |
porsche-tom |
Jul 3 2015, 10:27 AM
JeffBowlsby |
Jul 3 2015, 10:35 AM
That looks like the fuel lines on the passenger side of the tunnel.
The clutch tube is on the drivers side of the tunnel. |
porsche-tom |
Jul 3 2015, 12:08 PM
rgalla9146 |
Jul 3 2015, 12:32 PM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The clip does look OK but that doesn't guarantee the tube is attached to it.
Have someone step on the clutch pedal while you watch the tube with the mirror. While you have an assistant pushing the pedal watch the clutch tube where it exits the bulkhead in front of the engine. Look at the cable itself. Is fraying anywhere ? Is the pulley OK ? |
Jul 3 2015, 01:25 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Before you do any cutting or welding, I have a question for you.
Have you recently replaced the pedal bushings? Even if not, check the position of the clutch pedal on the cross-shaft. The roll pin that holds the pedal arm onto the cross-shaft can break (especially the ones that come with the bronze bushing sets!) and it will behave as you describe. For a while, then it won't release at all. --DD |
barefoot |
Jul 3 2015, 01:40 PM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
kkid |
Jul 4 2015, 08:30 AM
Before you do any cutting or welding, I have a question for you. Have you recently replaced the pedal bushings? Even if not, check the position of the clutch pedal on the cross-shaft. The roll pin that holds the pedal arm onto the cross-shaft can break (especially the ones that come with the bronze bushing sets!) and it will behave as you describe. For a while, then it won't release at all. --DD (IMG:style_emoticons/default/agree.gif) Is the roll pin with the set spiral type or split type? |
Jul 4 2015, 10:47 AM
The original is a spiral pin. The Weltmeister replacement is a split pin. That's why it fails after a relatively short period of use.
--DD |
Lo-Fi Version | Time is now: 19th April 2024 - 05:52 AM |
