pump power, now we're spinning |
rhodyguy |
Jun 7 2003, 09:40 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
bit the bullet. i was not looking forward to pulling through the wire harness. remembered i removed the small fi return line. ran the wire through the grommet and followed the harness to a switched supply. a quantum leap, i spent the better part of 2 days trying to sort out the stock pump wire issue. sometimes the simplest route is the easiest. correct? hell no! works? hell yes. later guys.
krevin |
DNHunt |
Jun 7 2003, 10:16 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
QUOTE i spent the better part of 2 days trying to sort out the stock pump wire issue. sometimes the simplest route is the easiest. correct? hell no! works? hell yes. later guys. Probably don't have to mention this but, I hope you keep notes. Little details like that just kind of disappear for me then, if I really need it when something fails, it's "OH S**T how the F**K did I do that". Bang around, throw a couple of tools and generally be a complete ass until the light bulb goes on and I remember what I did. I have a 3" ring binder with diagrams and notes on my FI project. I know I won't need all of that info but I don't what piece I'll need so I got it all. I still plan to throw some tools and cuss a little cause I'm sure when something busts I won't remember where the binder is. I'm sure there is some Murphy's Law corrollary that applies to 914's and especially 914 owners. Something like if something is going to bust it will bust at the least opportune time (like in front of a bunch of 911 owners) and it will be the one thing that is most obvious you juryrigged. On top of that you won't have the right tool to fix it and one of the 911 guys will say " Looks like you need these pliers so you can fix that yellow wire that's attached to the red wire and the green wire. Never did understand how these things ever worked". And all you can think of to say is "thanks Asshole". What a nightmare Dave |
Lo-Fi Version | Time is now: 15th May 2024 - 09:26 PM |
