Is this the death knell? (Oil light on when hot) |
PDXMike |
Jul 11 2015, 12:17 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
I was creeping along in traffic the other day, about 89 degrees out, when my oil light started to flicker on whenever I dropped the RPM's a bit when engaging the clutch. I've always been able to make this happen if I REALLY lugged the engine down, just about stalling it, but this was unusual. It started to get the point when letting the RPM's anywhere below idle (900 or so) the light would come on, and it would even blink a little at idle. Luckily I was at my destination so I just shut everything down. I checked the oil (which was fine) but the dipstick was so hot I could barely hold it even using a crumpled up paper towel. I towed the car home and let it cool down. When I started it up to pull it in the driveway everything was back to normal. The oil light turned off quickly after start-up and would even stay off for a second or two after I stalled out the engine. How bad is this? It could be something as simple as the oil pressure sender, right? It doesn't HAVE to be horrible, does it? Or should I be thinking about what kind of great upgrades I'll make during my rebuild? -Mike |
Dave_Darling |
Jul 11 2015, 01:59 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The owner's manual says that it is normal for the oil light to flicker at warm idle. I personally think that it's a sign of a somewhat tired motor, at least under "normal" circumstances. It sounds like you got things a bit too warm--barely able to handle the dipstick with a paper towel is probably closer to too hot than too cold.
If yours was flickering (not on steady) at below idle RPMs, that's even less of a concern than if it were to happen at idle. Change the oil and see if this happens again. If it does, then I suggest buying or borrowing one of the dipstick oil temp gauges so you can see how hot things are getting. --DD |
Lo-Fi Version | Time is now: 15th May 2024 - 01:30 PM |
