Is this the death knell? (Oil light on when hot) |
PDXMike |
Jul 11 2015, 12:17 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
I was creeping along in traffic the other day, about 89 degrees out, when my oil light started to flicker on whenever I dropped the RPM's a bit when engaging the clutch. I've always been able to make this happen if I REALLY lugged the engine down, just about stalling it, but this was unusual. It started to get the point when letting the RPM's anywhere below idle (900 or so) the light would come on, and it would even blink a little at idle. Luckily I was at my destination so I just shut everything down. I checked the oil (which was fine) but the dipstick was so hot I could barely hold it even using a crumpled up paper towel. I towed the car home and let it cool down. When I started it up to pull it in the driveway everything was back to normal. The oil light turned off quickly after start-up and would even stay off for a second or two after I stalled out the engine. How bad is this? It could be something as simple as the oil pressure sender, right? It doesn't HAVE to be horrible, does it? Or should I be thinking about what kind of great upgrades I'll make during my rebuild? -Mike |
injunmort |
Jul 11 2015, 03:53 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
10-30 is too thin for those temps change your oil to 20-50, Valvoline vr racing, most flaps carry it. in the summer I run strait 50wt oil in all my aircooled engines
gfg3 |
Jul 11 2015, 04:21 PM
Never Too Old Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
10-30 is too thin for those temps change your oil to 20-50, Valvoline vr racing, most flaps carry it. in the summer I run strait 50wt oil in all my aircooled engines (IMG:style_emoticons/default/agree.gif) Summer temps above 85 degrees require 20W50 or thicker regardless of which brand you prefer. I use Valvoline VR racing here in Virginia and all is OK. G |
Lo-Fi Version | Time is now: 16th May 2024 - 03:06 AM |
