Bad rings in Cylinder 3, 1.7 Build up to 1911cc motor |
Alphaogre |
Jul 30 2015, 02:24 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
I ran into another issue. I am buying all the new hardware for all the stripped or messed up bolts that I have gotten while taking the motor apart.
I found all of them except for the 3 allen/hex bolts that hold the fan to the motor. 2 of them were stripped and so I had to drill and pull them out. Do these bolts have a certain name or need to only be threaded at the end (like Stock) or are these just a standard allan/hex bolt? I searched on pelican, 914rubber, and some of the other "Go To" sites and cant seem to find them. (IMG:style_emoticons/default/confused24.gif) |
Olympic 914 |
Jul 30 2015, 03:06 PM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
On a slightly different note.... Do Not Disassemble the FAN. it is a PITA to get back right and be in balance, even if you mark its orientation.
porschetub |
Jul 30 2015, 06:29 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Best to drill the heads off the stripped ones,or maybe drive in a slighty larger inhex socket the hammer blows will free the tension and they should come out.
Replace them with a high tensile capscrew anything from grade 8-10 will be fine. Are you sure you don't just have a bad valve ,unusual for one cylinder to dump that much compression...unless you have broken rings,was it burning much oil?,just asking cheers |
Lo-Fi Version | Time is now: 1st June 2024 - 08:32 AM |
