> Found the problem, its not looking good & it gets worse
DavidSweden
post Jul 14 2015, 04:32 AM
Post #21
Some of you may have read my earlier pleas for help when my engine suddenly would not start. I thought it was the FI but after following the advice of members I did a compression and leak down test and discovered Zero compression and 100% leakage on #2.
With a heavy heart I pulled the engine, the pictures say it all.
I had the heads rebuilt earlier this year and have not done more than 300 miles. (IMG:style_emoticons/default/mad.gif)
Some questions:
what else needs to be checked for damage?
I need some new heads does anyone have some ready to use heads for a 75 2.0?
I guess the piston is also unusable, if I get some aftermarket P&C can I just install them without replacing the bushings on the connecting rods?
I guess the summer will be over before the engine is fixed.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1436869957.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1436869958.2.jpg)
DavidSweden   Found the problem   Jul 14 2015, 04:32 AM
falcor75   Aow that really sucks :(   Jul 14 2015, 04:56 AM
wndsrfr   Looks to me that you should get the valve seat rep...   Jul 14 2015, 05:52 AM
billh1963   I would like to think that the piston is okay....b...   Jul 14 2015, 06:05 AM
RobW   What a bummer, but at least you are going for it...   Jul 14 2015, 06:24 AM
Cairo94507   Oh no! That sucks beyond belief. I hope dama...   Jul 14 2015, 06:47 AM
Cj Honeycutt   The pistons take a much worse pounding with each c...   Jul 14 2015, 07:09 AM
cwpeden   That doesn't look so bad. Head can be saved. ...   Jul 14 2015, 07:25 AM
914_teener   That doesn't look so bad. Head can be saved. ...   Jul 14 2015, 08:56 AM
Mark Henry   When rebuilt was the seat replaced? Seat looks od...   Jul 14 2015, 09:09 AM
Valy   The piston is good, just buff the top. The head ne...   Jul 14 2015, 09:24 AM
screenguy914   Some here have pretty good observation skills to a...   Jul 14 2015, 10:45 AM
Cj Honeycutt   The piston crown is designed to take much abuse. S...   Jul 14 2015, 11:10 AM
DavidSweden   The piston crown is designed to take much abuse. ...   Jul 17 2015, 11:08 AM
whitetwinturbo   .......................unless the pins holding the...   Jul 14 2015, 01:17 PM
Cj Honeycutt   The piston pin is THE most robust part of the enti...   Jul 14 2015, 01:41 PM
rfinegan   If the lands are not damaged then blending the edg...   Jul 17 2015, 11:18 AM
veekry9   Buff? Nah,Pull the cylinders,check the rod for ben...   Jul 17 2015, 02:36 PM
Dave_Darling   Send BOTH HEADS to Len at HAM. One intake seat ca...   Jul 17 2015, 07:35 PM
Cj Honeycutt   Send BOTH HEADS to Len at HAM. One intake seat c...   Jul 18 2015, 05:37 PM
McMark   Safe way: check everything Fast way: leave the cyl...   Jul 17 2015, 10:38 PM
euro911   I've had worse looking pistons. I had about 70...   Jul 19 2015, 01:31 AM
Dave_Darling   I gave one shop three chances at that. I finally ...   Jul 19 2015, 10:39 AM
brant   There is a chance the rod is now slightly bent. S...   Jul 19 2015, 11:09 AM
rhodyguy   Shipping a set back and forth will cost a fortune....   Jul 19 2015, 12:23 PM
euro911   Shipping a set back and forth will cost a fortune....   Jul 19 2015, 01:02 PM
DavidSweden   Shipping a set back and forth will cost a fortune...   Jul 19 2015, 02:13 PM
rhodyguy   See post #1 mark.   Jul 19 2015, 01:22 PM
euro911   See post #1 mark.I know my eyes have gotten worse ...   Jul 19 2015, 02:06 PM
Cj Honeycutt   Agree with taking them back for a refund, but NOT ...   Jul 19 2015, 05:57 PM
DavidSweden   I pulled the head for #3/4 this afternoon and got...   Jul 20 2015, 09:57 AM
Cj Honeycutt   Crap ! In this case, the push rod is almost fo...   Jul 20 2015, 10:37 AM
Valy   When did you last adjust the valves? Did you have ...   Jul 20 2015, 11:53 AM
DavidSweden   When did you last adjust the valves? Did you have...   Jul 20 2015, 12:06 PM
stugray   Perhaps the rocker failure and the seat failure ...   Jul 20 2015, 05:34 PM
DavidSweden   Perhaps the rocker failure and the seat failure...   Jul 21 2015, 02:20 AM
DavidSweden   The shop that rebuilt my heads opened today after ...   Jul 27 2015, 10:31 AM
Valy   The shop that rebuilt my heads opened today after...   Jul 27 2015, 06:16 PM
Spoke   In other words it was not due to a bad workmanshi...   Jul 27 2015, 08:26 PM
euro911   Interesting that you didn't see low compressio...   Jul 20 2015, 02:26 PM
DavidSweden   Interesting that you didn't see low compressi...   Jul 20 2015, 02:56 PM
Valy   Can you push open the valves that broke/bent the v...   Jul 20 2015, 02:58 PM
DavidSweden   Can you push open the valves that broke/bent the ...   Jul 20 2015, 03:14 PM
arkitect   Makes me wonder what the shop did wrong that the s...   Jul 21 2015, 03:42 AM
Racer Chris   No, the shop owner is a lying liar.   Jul 27 2015, 11:44 AM
Dave_Darling   No, the shop owner is a lying liar. Either that...   Jul 27 2015, 08:18 PM
porschetub   Some shops have no idea how much interferance fit ...   Jul 27 2015, 02:04 PM
Cairo94507   I would say to post the name of the shop.....but g...   Jul 27 2015, 05:23 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:13 PM
