| DavidSweden |
Jul 14 2015, 04:32 AM
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Some of you may have read my earlier pleas for help when my engine suddenly would not start. I thought it was the FI but after following the advice of members I did a compression and leak down test and discovered Zero compression and 100% leakage on #2.
With a heavy heart I pulled the engine, the pictures say it all. I had the heads rebuilt earlier this year and have not done more than 300 miles. (IMG:style_emoticons/default/mad.gif) Some questions: what else needs to be checked for damage? I need some new heads does anyone have some ready to use heads for a 75 2.0? I guess the piston is also unusable, if I get some aftermarket P&C can I just install them without replacing the bushings on the connecting rods? I guess the summer will be over before the engine is fixed. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1436869957.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1436869958.2.jpg) |
DavidSweden Found the problem Jul 14 2015, 04:32 AM
falcor75 Aow that really sucks :( Jul 14 2015, 04:56 AM
wndsrfr Looks to me that you should get the valve seat rep... Jul 14 2015, 05:52 AM
billh1963 I would like to think that the piston is okay....b... Jul 14 2015, 06:05 AM
RobW What a bummer, but at least you are going for it... Jul 14 2015, 06:24 AM
Cairo94507 Oh no! That sucks beyond belief. I hope dama... Jul 14 2015, 06:47 AM
Cj Honeycutt The pistons take a much worse pounding with each c... Jul 14 2015, 07:09 AM
cwpeden That doesn't look so bad. Head can be saved.
... Jul 14 2015, 07:25 AM
914_teener
... Jul 14 2015, 08:56 AM
Mark Henry When rebuilt was the seat replaced?
Seat looks od... Jul 14 2015, 09:09 AM
Valy The piston is good, just buff the top.
The head ne... Jul 14 2015, 09:24 AM
screenguy914 Some here have pretty good observation skills to a... Jul 14 2015, 10:45 AM
Cj Honeycutt The piston crown is designed to take much abuse. S... Jul 14 2015, 11:10 AM
DavidSweden
The piston crown is designed to take much abuse. ... Jul 17 2015, 11:08 AM
whitetwinturbo .......................unless the pins holding the... Jul 14 2015, 01:17 PM
Cj Honeycutt The piston pin is THE most robust part of the enti... Jul 14 2015, 01:41 PM
rfinegan If the lands are not damaged then blending the edg... Jul 17 2015, 11:18 AM
veekry9 Buff?
Nah,Pull the cylinders,check the rod for ben... Jul 17 2015, 02:36 PM
Dave_Darling Send BOTH HEADS to Len at HAM. One intake seat ca... Jul 17 2015, 07:35 PM
Cj Honeycutt
Send BOTH HEADS to Len at HAM. One intake seat c... Jul 18 2015, 05:37 PM
McMark Safe way: check everything
Fast way: leave the cyl... Jul 17 2015, 10:38 PM
euro911 I've had worse looking pistons. I had about 70... Jul 19 2015, 01:31 AM
Dave_Darling I gave one shop three chances at that. I finally ... Jul 19 2015, 10:39 AM
brant There is a chance the rod is now slightly bent. S... Jul 19 2015, 11:09 AM
rhodyguy Shipping a set back and forth will cost a fortune.... Jul 19 2015, 12:23 PM
euro911 Shipping a set back and forth will cost a fortune.... Jul 19 2015, 01:02 PM
DavidSweden
Shipping a set back and forth will cost a fortune... Jul 19 2015, 02:13 PM
rhodyguy See post #1 mark. Jul 19 2015, 01:22 PM
euro911 See post #1 mark.I know my eyes have gotten worse ... Jul 19 2015, 02:06 PM
Cj Honeycutt Agree with taking them back for a refund, but NOT ... Jul 19 2015, 05:57 PM
DavidSweden I pulled the head for #3/4 this afternoon and got... Jul 20 2015, 09:57 AM
Cj Honeycutt Crap ! In this case, the push rod is almost fo... Jul 20 2015, 10:37 AM
Valy When did you last adjust the valves? Did you have ... Jul 20 2015, 11:53 AM
DavidSweden
When did you last adjust the valves? Did you have... Jul 20 2015, 12:06 PM
stugray
Perhaps the rocker failure and the seat failure ... Jul 20 2015, 05:34 PM
DavidSweden
Perhaps the rocker failure and the seat failure... Jul 21 2015, 02:20 AM
DavidSweden The shop that rebuilt my heads opened today after ... Jul 27 2015, 10:31 AM
Valy
The shop that rebuilt my heads opened today after... Jul 27 2015, 06:16 PM
Spoke
In other words it was not due to a bad workmanshi... Jul 27 2015, 08:26 PM
euro911 Interesting that you didn't see low compressio... Jul 20 2015, 02:26 PM
DavidSweden
Interesting that you didn't see low compressi... Jul 20 2015, 02:56 PM
Valy Can you push open the valves that broke/bent the v... Jul 20 2015, 02:58 PM
DavidSweden
Can you push open the valves that broke/bent the ... Jul 20 2015, 03:14 PM
arkitect Makes me wonder what the shop did wrong that the s... Jul 21 2015, 03:42 AM
Racer Chris No, the shop owner is a lying liar. Jul 27 2015, 11:44 AM
Dave_Darling
Either that... Jul 27 2015, 08:18 PM
porschetub Some shops have no idea how much interferance fit ... Jul 27 2015, 02:04 PM
Cairo94507 I would say to post the name of the shop.....but g... Jul 27 2015, 05:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:12 PM |
