Horn set up with Momo wheel |
ChrisReale |
Jun 7 2003, 08:35 PM
Ok, I figure its time to get my horn working before some a-hole drives over me in their Hummer.
Put a Momo wheel on a few months back, swapped the horn ring onto the wheel, hooked up the one wire that worked for the stock wheel, and no horn. I turn the wheel left or right I got horn. Finally removed the horn relay. On the back of the horn button there is two tabs to hook wires up to. One goes from the stock horn ring to one tab. What do I do with the other. Ground it? Where? What have you done with it? |
Jun 7 2003, 09:28 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the horn button is supposed to ground itself. mine has metal clips on the side to snap in. they provide the ground connection, IF your adapter is metal all the way. if not, you need to find ground.
the adapter usually grounds through the steering column. you should be able to test your horn setup by grounding the wire that goes to the horn button manually while turning the steering wheel. the horn should go off at any position ... sorry, don't have pictures, Andy |
Qarl |
Jun 7 2003, 09:55 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I couple of options..
1. Check the back of the horn button. Some have two spade connectors. One is labeled ground and one is for the button itself. if this is the case then your ground to the adapter the ground spade connector and connec the thru-wire for the horn ring to the other spade connector. 2. Another of my Momo buttons has only one spade connector, but also a large metal coil spring coming out of the back. This comes into contact with the hub adapter housing and provides ground. I prefer horn button 1 |
ChrisReale |
Jun 7 2003, 10:08 PM
Thanks Andy and Karl, I got it to work.
Turns out, the horn was grounding itself out at the point where the wire goes into the horn ring. I wrapped it up with electrical tape. Also, the spring that is supposed to touch the colum on the back of the horn button was not long enough, so i ran a wire to the column, and it works now. Now all I have to do is figure out how to makethe horn sound like a Chebby horn :cursor: |
Qarl |
Jun 7 2003, 10:11 PM
Mash the Porsche logo down (in).
If it doesn't move, then you have to mess with the spring inside. It can easily come apart. Just disassemble it and you can see how the spring action works. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:06 PM |
