Horn set up with Momo wheel |
ChrisReale |
Jun 7 2003, 08:35 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Ok, I figure its time to get my horn working before some a-hole drives over me in their Hummer.
Put a Momo wheel on a few months back, swapped the horn ring onto the wheel, hooked up the one wire that worked for the stock wheel, and no horn. I turn the wheel left or right I got horn. Finally removed the horn relay. On the back of the horn button there is two tabs to hook wires up to. One goes from the stock horn ring to one tab. What do I do with the other. Ground it? Where? What have you done with it? |
Qarl |
Jun 7 2003, 09:55 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I couple of options..
1. Check the back of the horn button. Some have two spade connectors. One is labeled ground and one is for the button itself. if this is the case then your ground to the adapter the ground spade connector and connec the thru-wire for the horn ring to the other spade connector. 2. Another of my Momo buttons has only one spade connector, but also a large metal coil spring coming out of the back. This comes into contact with the hub adapter housing and provides ground. I prefer horn button 1 |
Lo-Fi Version | Time is now: 19th May 2024 - 05:14 AM |
