Flywheel cut 0.012 or 12 Thousandths, do I need a pivot ball shim? |
LukeD |
Jul 22 2015, 12:19 PM
Member Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
Flywheel was just machine turned at 12 thousands (0.012), machinist said it was hardly any material removed to get a good surface, do I need to put a shim under the pivot ball to make up this difference?
Thank you |
Lo-Fi Version | Time is now: 19th May 2024 - 05:12 PM |
