Ot for People thinking of Garage Painting |
bandjoey |
Jul 24 2015, 09:55 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
For home painters. I've been wondering what compressor size is needed for painting and found this. Air compressors Explained and Tested.
https://m.youtube.com/watch?feature=em-subs...p;v=cqae1rEwIKw Ok I've played with embedding this and it doesn't work. I used the 'help' and couldn't make it work. Thanks Please fix and post below how you made it work. |
Chris H. |
Jul 24 2015, 10:32 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Chris H. |
Jul 24 2015, 10:36 AM
So you just need the embed code which is the code after v= but before the &app in this case. yours is cqae1rEwIKw Click the URL and you will see it towards the end.
To post a vid you put... youtube in brackets first [] then the embed code with no spaces, then /youtube in brackets [] Try it! |
Mark Henry |
Jul 24 2015, 01:01 PM
I don't have time to look at the links, but I'd get the biggest you can afford. Personally I wouldn't get under a 5hp/60-gal.
ThePaintedMan |
Jul 24 2015, 01:28 PM
I don't have time to look at the links, but I'd get the biggest you can afford. Personally I wouldn't get under a 5hp/60-gal. (IMG:style_emoticons/default/agree.gif) You can paint a car with a very small compressor. But that doesn't say anything about how nice it is to have a DA for sanding... which will make even the best compressors do some work. |
Lo-Fi Version | Time is now: 21st May 2024 - 08:39 AM |
