Porsche 914/Subaru svx build |
mepstein |
Jul 25 2015, 11:28 AM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Parts acquisition
Attached image(s) |
Amenson |
Jan 9 2019, 09:40 PM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
Had an interesting discussion going so I moved it to the proper place...
Scott the flip is not hard, some of the stuff just needs to moved to make it happen, like we talked about. Once you see the EG you will know. The IRIS system is what clutters up the flip. I don't think You're going to have an issue with it. It is very easy if Mark is not going to have AC in the car, becomes harder if Mark is. Workshop is looking great, let me know if there is anything you need from me to help these along. (IMG:style_emoticons/default/poke.gif) Yeah I know of 5 little round items you need all ready (IMG:style_emoticons/default/huh.gif) I don’t want to turn this into a thread for my car but...I do want a/c & heat. I was hoping the bulkhead mount might make things a bit easier with positioning but that might not be the case. My plan is not to micromanage the build but to turn it over to Scott A and let him do his thing. The only challenge I see with the build is Scott likes to build to a high standard for both looks and functionality and I’m looking for a good running conversion but not a showcase car. I’m sure it will work out. The nice thing is with my car is there is no fresh paint to worry about. (IMG:style_emoticons/default/lol-2.gif) Fresh paint, and yes this is about PorSTI, we just started talking about EG33 intake flips. I am a huge proponent that the bulkhead mounts for the EG, if anything it allows for even better positioning of the engine giving the clearance needed for the flip. Mark I am sure a build thread will be started to discuss your car, once the process starts. Oh, don't worry your car will be built to a high standard for looks and functionality...efficiently. Getting the engine sitting properly in the available space is key. Ditching the cradle will help a lot and I think that we should consider a shortened oil pan. Lowering the engine should open up enough space to flip the manifold so that we can shift the engine back and get the axles straight (and use an electric motor AC compressor maybe) or leave it as is keep AC either way keeping the trunk uncut. It would be a shame to hack it up after spending the time to install the the donor trunk section. PorSTi has a shortened pan from Outfront but I am not sure if they do one for the EG. If not small car has a nice cast aluminum EG pan. Tom wants heat on Grey also so I added connections to the radiator lines for it. I have concept for a heater but Grey doesn't have all of the air diverters and stuff installed for mock-up and quite frankly I need to end scope creep on the project so so that Tom can have it back in time to have the opportunity to do final assembly before spring. We can develop it on your car. |
mepstein |
Jan 9 2019, 09:51 PM
Had an interesting discussion going so I moved it to the proper place... Scott the flip is not hard, some of the stuff just needs to moved to make it happen, like we talked about. Once you see the EG you will know. The IRIS system is what clutters up the flip. I don't think You're going to have an issue with it. It is very easy if Mark is not going to have AC in the car, becomes harder if Mark is. Workshop is looking great, let me know if there is anything you need from me to help these along. (IMG:style_emoticons/default/poke.gif) Yeah I know of 5 little round items you need all ready (IMG:style_emoticons/default/huh.gif) I don’t want to turn this into a thread for my car but...I do want a/c & heat. I was hoping the bulkhead mount might make things a bit easier with positioning but that might not be the case. My plan is not to micromanage the build but to turn it over to Scott A and let him do his thing. The only challenge I see with the build is Scott likes to build to a high standard for both looks and functionality and I’m looking for a good running conversion but not a showcase car. I’m sure it will work out. The nice thing is with my car is there is no fresh paint to worry about. (IMG:style_emoticons/default/lol-2.gif) Fresh paint, and yes this is about PorSTI, we just started talking about EG33 intake flips. I am a huge proponent that the bulkhead mounts for the EG, if anything it allows for even better positioning of the engine giving the clearance needed for the flip. Mark I am sure a build thread will be started to discuss your car, once the process starts. Oh, don't worry your car will be built to a high standard for looks and functionality...efficiently. Getting the engine sitting properly in the available space is key. Ditching the cradle will help a lot and I think that we should consider a shortened oil pan. Lowering the engine should open up enough space to flip the manifold so that we can shift the engine back and get the axles straight (and use an electric motor AC compressor maybe) or leave it as is keep AC either way keeping the trunk uncut. It would be a shame to hack it up after spending the time to install the the donor trunk section. PorSTi has a shortened pan from Outfront but I am not sure if they do one for the EG. If not small car has a nice cast aluminum EG pan. Tom wants heat on Grey also so I added connections to the radiator lines for it. I have concept for a heater but Grey doesn't have all of the air diverters and stuff installed for mock-up and quite frankly I need to end scope creep on the project so so that Tom can have it back in time to have the opportunity to do final assembly before spring. We can develop it on your car. Like I said, I’m not going to micromanage the build. I’ll just sit back, watch and be surprised. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 27th April 2024 - 03:48 AM |
