Blue Porscheru Conversion, Subaru 2.5 SOHC NA with Suby Tranny |
R_u_dd |
Jul 25 2015, 11:09 PM
Member Group: Members Posts: 154 Joined: 3-March 14 From: Grants Pass, Oregon Member No.: 17,072 Region Association: Pacific Northwest |
I started this project back in May of 2014 and wanted to share the journey with my friends and family. There's something appealing to people about taking a left-for-dead vehicle and bringing it back to life. I hope this build thread is a bit different than the others. It's a Subaru conversion which is not as common. I am/was a newbie. This is my first car restoration, if you can call it that. My welds are not pretty, but I've improved and learned throughout this process. This is a great car for a first restoration. It's light, simple, and very cool- mid engine with a targa top. This is the plan- We are starting with a 1971 tangerine 914 with light to moderate rust, nothing too serious. The original engine was a 1.7. Like so many other 914's it ran but has been sitting for a long time. The engine seems too far gone to try to rebuild it= lots of rust and corrosion. Powerplant: 2003 Subaru Impreza TS 2.5 SOHC, Natuaral- No Turbo, Why? Plenty of Power for me and no turbo lag. See Engine Choices thread. Transmission: Subaru 5MT 2003 Impreza TS ECU from: 2003 Subaru Impreza TS Electronics: Wiring Harness simplified by Small Car Performance Axles: 944 axles and CV's with Subaru inside CV- 4 lug for now. 914 suspension. No fender flares Voltage Blue Metallic: (Honda color), Painted Sail Panels. Before Pictures (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1486250894.1.jpg) The Future Look- Concepts The 914 visualizer, a very cool app. Current Look: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919164.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919164.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919165.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1459666779.1.jpg) Contents Axles Blasting Glass Bead Videos Battery Tray Area Battery and Tray Budget Scenarios Brakes Bumper - Valence Clutch Electronics Engine Discussion Engine Mount Engine Work Floor Pans and Engman Kit Fuel Pump Fuel Tank (Cleaning with Electrolysis) Paint Prep and Metal Work Paint Prep Continued Radiator Seats and Interior Seats Re-upholstery Links Transmission Transmission Mount Videos This thread is for entertainment purposes only. I am not a certified mechanic. There are many that have pioneered the suby conversion before me, but this is my story. Hope you enjoy this thread! Chris (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1486249676.1.jpg) |
mgp4591 |
Jul 30 2015, 12:28 AM
914 Guru Group: Members Posts: 5,378 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Do you have the cast engine bracket or the other style? I've seldom seen the cast style weld up strong enough to the brackets to be safe enough for my tastes- not pointing fingers or anything, just curious as to what others are doing for the Subie mounting situation... Thanks! (IMG:style_emoticons/default/popcorn[1].gif)
R_u_dd |
Jul 30 2015, 10:18 PM
Do you have the cast engine bracket or the other style? I've seldom seen the cast style weld up strong enough to the brackets to be safe enough for my tastes- not pointing fingers or anything, just curious as to what others are doing for the Subie mounting situation... Thanks! (IMG:style_emoticons/default/popcorn[1].gif) Looks like it's welded steel to me. The cast mount is used in the later models with the pass-through hole for the shift rod on the side shifter transmission. The plan is to follow the design of Amenson in his PorSti Build as shown in post #2. He drills through and bolts onto the bracket rather than welding directly to it. My goal is to try to mount the engine forward as much as possible to center the engine in the engine bay and avoid cutting the trunk. Since there is no turbo, I should have enough clearance to avoid cutting the trunk even if it has to be mounted further back than I would like. The axles will need to be aligned at a slight angle for proper lubrication of the CV joints. It will be a critical step to mount the engine correctly. It is also important to get the transmission level to keep 4th and 5th gear oiled properly. |
mgp4591 |
Jul 30 2015, 10:29 PM
Do you have the cast engine bracket or the other style? I've seldom seen the cast style weld up strong enough to the brackets to be safe enough for my tastes- not pointing fingers or anything, just curious as to what others are doing for the Subie mounting situation... Thanks! (IMG:style_emoticons/default/popcorn[1].gif) The plan is to follow the design of Amenson in his PorSti Build as shown in post #2. He drills through and bolts onto the bracket rather than welding directly to it. My goal is to try to mount the engine forward as much as possible to center the engine in the engine bay and avoid cutting the trunk. Since there is no turbo, I should have enough clearance to avoid cutting the trunk even if it has to be mounted further back than I would like. The axles will need to be aligned at a slight angle for proper lubrication of the CV joints. It will be a critical step to mount the engine correctly. It is also important to get the transmission level to keep 4th and 5th gear oiled properly. I thought I'd studied that thread over and over- somehow I missed that bit right there! That's exactly what I was looking for, and the other comments give me confidence to use that for my EG33 swap- thanks for the help! |
Lo-Fi Version | Time is now: 26th May 2024 - 04:29 AM |
