Blue Porscheru Conversion, Subaru 2.5 SOHC NA with Suby Tranny |
R_u_dd |
Jul 25 2015, 11:09 PM
Member Group: Members Posts: 154 Joined: 3-March 14 From: Grants Pass, Oregon Member No.: 17,072 Region Association: Pacific Northwest |
I started this project back in May of 2014 and wanted to share the journey with my friends and family. There's something appealing to people about taking a left-for-dead vehicle and bringing it back to life. I hope this build thread is a bit different than the others. It's a Subaru conversion which is not as common. I am/was a newbie. This is my first car restoration, if you can call it that. My welds are not pretty, but I've improved and learned throughout this process. This is a great car for a first restoration. It's light, simple, and very cool- mid engine with a targa top. This is the plan- We are starting with a 1971 tangerine 914 with light to moderate rust, nothing too serious. The original engine was a 1.7. Like so many other 914's it ran but has been sitting for a long time. The engine seems too far gone to try to rebuild it= lots of rust and corrosion. Powerplant: 2003 Subaru Impreza TS 2.5 SOHC, Natuaral- No Turbo, Why? Plenty of Power for me and no turbo lag. See Engine Choices thread. Transmission: Subaru 5MT 2003 Impreza TS ECU from: 2003 Subaru Impreza TS Electronics: Wiring Harness simplified by Small Car Performance Axles: 944 axles and CV's with Subaru inside CV- 4 lug for now. 914 suspension. No fender flares Voltage Blue Metallic: (Honda color), Painted Sail Panels. Before Pictures (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1486250894.1.jpg) The Future Look- Concepts The 914 visualizer, a very cool app. Current Look: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919164.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919164.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919165.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1459666779.1.jpg) Contents Axles Blasting Glass Bead Videos Battery Tray Area Battery and Tray Budget Scenarios Brakes Bumper - Valence Clutch Electronics Engine Discussion Engine Mount Engine Work Floor Pans and Engman Kit Fuel Pump Fuel Tank (Cleaning with Electrolysis) Paint Prep and Metal Work Paint Prep Continued Radiator Seats and Interior Seats Re-upholstery Links Transmission Transmission Mount Videos This thread is for entertainment purposes only. I am not a certified mechanic. There are many that have pioneered the suby conversion before me, but this is my story. Hope you enjoy this thread! Chris (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1486249676.1.jpg) |
DBCooper |
Nov 14 2015, 06:24 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I'd say you're too far. You say it's 22 degrees now? At ride height? Then what's the angle get to at top and bottom of the suspension travel? That should add a few degrees. Also it's true that not being at zero degrees is preferable for lubrication of the CV's, but I don't think that running at the maximum angle all the time is going to work for very long. That's a LOT of movement inside the CV each revolution.
R_u_dd |
Nov 14 2015, 09:04 PM
I'd say you're too far. You say it's 22 degrees now? At ride height? Then what's the angle get to at top and bottom of the suspension travel? That should add a few degrees. Also it's true that not being at zero degrees is preferable for lubrication of the CV's, but I don't think that running at the maximum angle all the time is going to work for very long. That's a LOT of movement inside the CV each revolution. Yeah, giving this some thought. I might just have to scoot the engine/tranny back a couple inches. If I flip the manifold, I might not have to cut the trunk. The problem with using the Suby tranny is that the stubs are forward of the 901 which pushes the engine back and the weight is pushed from the mid-engine arrangement closer to the back. Another idea is to try the 930 CV's which will go up to a 25 degree angle. Those are 28 spline though and I would have to respline both ends of the axles. The dollars start to add up fast. I am still curious if anyone has run their axles at this angle for some miles????? |
Lo-Fi Version | Time is now: 18th May 2024 - 06:02 PM |
