tune up, Timing |
tune up, Timing |
cpavlenko |
Jul 26 2015, 09:22 AM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I usually have my tune up done by Aircooleds Only. But now on a tight budget, and I have a ?. My Haynes manual says for timing to undo vac hose to diz, and bring the rpm to 3500. y is this. Just wondering. oh, it's a stock 1.7 FI engine.
cpavlenko |
Jul 26 2015, 11:46 AM
brant |
Jul 26 2015, 11:57 AM
914 Wizard Group: Members Posts: 11,619 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the advance weights in the distributor throw outward as rpm increases...
(increasing the total advance of to the motor) so at 3500rpm they are maxed in their travel if you time below 3500rpm, or below max advance... you are not reading an accurate number and the motor will continue to gain advance as it revs example: if you set 29degree's of advance at idle. you will have much more advance on the road as the car is at higher rpm you will then have too much advance leading to pre-detonation, higher temps, poor running, and eventually a holed piston follow the manual |
cpavlenko |
Jul 26 2015, 12:38 PM
the advance weights in the distributor throw outward as rpm increases... (increasing the total advance of to the motor) so at 3500rpm they are maxed in their travel if you time below 3500rpm, or below max advance... you are not reading an accurate number and the motor will continue to gain advance as it revs example: if you set 29degree's of advance at idle. you will have much more advance on the road as the car is at higher rpm you will then have too much advance leading to pre-detonation, higher temps, poor running, and eventually a holed piston follow the manual Thanks for your input, makes sense. I'll b getting my new plugs, diz rotor, cap and plug wires Tuesday. Going to run ngk 6bes (7432 ) and time as the manual says. |
cpavlenko |
Jul 28 2015, 09:14 PM
Ok, I'm looking at timing hole, facing the firewall towards the front of 914. So as I'm looking towards the front, and I see tdc, is before tdc to the right or left? I hope I'm making sense.
TheCabinetmaker |
Jul 29 2015, 04:18 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Left. Towards the drivers side
cpavlenko |
Jul 29 2015, 07:10 AM
Elliot Cannon |
Jul 29 2015, 10:39 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
3500 rpm can be a little noisy. Ear protection makes this job a lot more comfortable.
Attached image(s) |
cpavlenko |
Jul 29 2015, 01:53 PM
One more ? When i remove the vac hose, do i need to plug the hose.
BeatNavy |
Jul 29 2015, 03:56 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I believe you should (I do). This is a good read: Pelican Dwell and Timing Adjustment
Note that it's also best to set dwell before you do timing (if you have not already). |
cpavlenko |
Jul 29 2015, 04:41 PM
I believe you should (I do). This is a good read: Pelican Dwell and Timing Adjustment Note that it's also best to set dwell before you do timing (if you have not already). No points, pertronik electronic ignition. Is there still a dwell setting with the pertronik? Like i said in previous post, my first time doing this because of low budget and can't afford to take to my local aircooleds only mechanics . So I'm in the learning mode with the help of 914 world. And it's great to have all the knowledge given to me by this site. (IMG:style_emoticons/default/pray.gif) much appreciated. |
ThePaintedMan |
Jul 29 2015, 06:15 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
One more ? When i remove the vac hose, do i need to plug the hose. If you're going by the book - yes. You need to eliminate all sources of vacuum leaks. Did I miss this - is it carbed or fuel injected? Edit: Sorry, I saw that it's FI. Plug the hose coming from the plenum. Plug the hose wherever the source of vacuum is coming from (i.e. don't plug the distributor). |
cpavlenko |
Jul 29 2015, 06:26 PM
One more ? When i remove the vac hose, do i need to plug the hose. If you're going by the book - yes. You need to eliminate all sources of vacuum leaks. Did I miss this - is it carbed or fuel injected? Plug the hose wherever the source of vacuum is coming from (i.e. don't plug the distributor). Stock 1971, 1.7 fuel injected engine. |
Lo-Fi Version | Time is now: 5th May 2024 - 09:18 AM |
