tune up, Timing |
tune up, Timing |
cpavlenko |
Jul 26 2015, 09:22 AM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I usually have my tune up done by Aircooleds Only. But now on a tight budget, and I have a ?. My Haynes manual says for timing to undo vac hose to diz, and bring the rpm to 3500. y is this. Just wondering. oh, it's a stock 1.7 FI engine.
BeatNavy |
Jul 29 2015, 03:56 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I believe you should (I do). This is a good read: Pelican Dwell and Timing Adjustment
Note that it's also best to set dwell before you do timing (if you have not already). |
cpavlenko |
Jul 29 2015, 04:41 PM
I believe you should (I do). This is a good read: Pelican Dwell and Timing Adjustment Note that it's also best to set dwell before you do timing (if you have not already). No points, pertronik electronic ignition. Is there still a dwell setting with the pertronik? Like i said in previous post, my first time doing this because of low budget and can't afford to take to my local aircooleds only mechanics . So I'm in the learning mode with the help of 914 world. And it's great to have all the knowledge given to me by this site. (IMG:style_emoticons/default/pray.gif) much appreciated. |
Lo-Fi Version | Time is now: 25th May 2024 - 07:24 PM |
