Oooze from my trans---so what do I need? |
pSquared |
Jul 28 2015, 04:25 PM
Newbie Group: Members Posts: 7 Joined: 23-April 06 Member No.: 5,913 |
Getting a messy seep from where the arrow's pointing.
Betting I just remove the 2 - 13mm's that hold the shift housing and hopefully I can pull apart and replace the O-Ring I see in the parts diagram. Any other gaskets? Or anything else I should procure to stem the seepage? And where might I find? (hopefully there's no explosion of springs and microscopic little parts that come flying out when I pull the housing. Ask why I wonder...) Thanks in advance for any insight. p2 |
Spoke |
Jul 28 2015, 04:39 PM
Jerry Group: Members Posts: 6,984 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Common leak point. A couple of o rings and you're good to go.
Dr Evil |
Jul 28 2015, 07:04 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
1 O-ring and you are done. Clean the surface well. There should not be any gaskets on there. If there are, someone made a mistake. While your at it, might as well change the seal in the console. I think I have both. PM me and I will check. Need to do so soon as I am in the wind as of Thurs afternoon and not back until Mon.
Mblizzard |
Jul 28 2015, 07:40 PM
Follow the Dr.s advice and you won't go wrong.
And by the way, my trans is still AWESOME after the rebuild! I say a little thanks to the Dr on every drive. |
Lo-Fi Version | Time is now: 21st May 2024 - 09:13 PM |
