if you see the designer of the 914 rear caliper... |
dabird |
Jul 29 2015, 03:58 PM
Member Group: Members Posts: 94 Joined: 17-October 14 From: New Albany, IN Member No.: 18,025 Region Association: None |
please kick him in the balls for me. Thanks
bandjoey |
Jul 29 2015, 06:37 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Valy |
Jul 29 2015, 06:44 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
please kick him in the balls for me. Thanks I would just put a C clip on his balls and give him a toothpick to take it of. (IMG:style_emoticons/default/wacko.gif) |
914_teener |
Jul 29 2015, 06:56 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
please kick him in the balls for me. Thanks I would just put a C clip on his balls and give him a toothpick to take it of. (IMG:style_emoticons/default/wacko.gif) That must be the same guy that designed the front windsheild washer. |
eyesright |
Jul 30 2015, 08:38 AM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
please kick him in the balls for me. Thanks I would just put a C clip on his balls and give him a toothpick to take it of. (IMG:style_emoticons/default/wacko.gif) That must be the same guy that designed the front windsheild washer. And who let it out of the factory without inventing plastic inner fender liners??!! |
914forme |
Jul 30 2015, 10:51 AM
The rear caliper design was a common ATE caliper in the day. Used in other applications including the Ferrari 308. Leader screws are in the wrong spot, down low, when mounted on the 914 trailing arm. But they bolt right on, and allow you to run a vented rear rotor.
The design was fine, the years have not been as kind. Hindsight is always 20/20. Unfortunately the caliper was not in production to go through a redesign. While yes they should have just did the 911 e-brakes on the 914, sad to say they did not. Lucky that is an easy fix with a welder and a few parts. That being said, the last time I dealt with a 914-4 rear caliper was in the 80s on my Karmann Ghia (IMG:style_emoticons/default/biggrin.gif) |
Larmo63 |
Jul 30 2015, 03:17 PM
I love my stock 914-6 rears from PMB.
Jul 30 2015, 03:27 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Larmo63 |
Jul 30 2015, 03:35 PM
brant |
Jul 30 2015, 04:19 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The 911 e-brake with a second brake shoe is heavy and a waste of weight
914forme |
Jul 30 2015, 06:13 PM
scotty b |
Jul 30 2015, 06:43 PM
You should definitely steer clear of working on a Fjord Bronco II, a Maserati Bi-turdbo or a 928 if a 914 clapper is that much of a PITA (IMG:style_emoticons/default/rolleyes.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 12:22 PM |
