Type 4 frankenmotor- born in the basment of an undisclosed location |
chad newton |
Jul 29 2015, 07:42 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
chad newton |
Jul 29 2015, 07:45 PM
It must have bus heads, idk. It even comes with the really cool solexs.(IMG:style_emoticons/default/smile.gif)
JeffBowlsby |
Jul 29 2015, 08:46 PM
914 Wiring Harnesses Group: Members Posts: 8,438 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
That engine case code is a 66HP bus motor if its still stock.
chad newton |
Jul 29 2015, 09:38 PM
Hah, could be. I actually thought that c could be a g? But idk, the cb signifies a type 2 dosnt it?
Jonathan Livesay |
Jul 29 2015, 09:55 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
'72-'73 Type 2 1700 a bus motor all right.
That being said 1K is a bit high. (IMG:style_emoticons/default/dry.gif) |
chad newton |
Jul 29 2015, 10:08 PM
Can't be a type 2, no air box.
bdstone914 |
Jul 30 2015, 04:22 AM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
As a bus motor it will have hydraulic lifters. Was it in a running 914? If not it may still have the bus flywheel. Not interested just trying to get out the right info on the engine.
chad newton |
Jul 30 2015, 08:42 AM
It was in my 914 when I bought it, bolted to a sideshift, running.(IMG:style_emoticons/default/smile.gif). I really think its a 914 2 liter with bus heads.
JamesM |
Jul 30 2015, 10:07 AM
Senior Member Group: Members Posts: 1,872 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
It was in my 914 when I bought it, bolted to a sideshift, running.(IMG:style_emoticons/default/smile.gif). I really think its a 914 2 liter with bus heads. Heads are really what make a "914 2L" a "914 2L" Bottom end of the 914 and bus motors are pretty much the same, in this case though the case is a bus serial number as well. There is nothing here that is 914 2L specific, might explain the desire for a 6 as with this setup you were probably about 40HP down from a stock 914 2L. Not knowing what crank this thing actually has you are probably looking at 1.7 core motor prices (couple hundred bucks at best) |
chad newton |
Jul 30 2015, 10:40 AM
Well someone make me an offer, I just want to get it out of the back of my truck...
sean_v8_914 |
Jul 30 2015, 12:58 PM
where is it?
that might help to sell it |
Jul 30 2015, 01:01 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You should update your ad to reflect the product correctly
chad newton |
Jul 30 2015, 02:41 PM
Hah, I'm going to leave just to piss u off
Jul 30 2015, 03:19 PM
euro911 |
Jul 30 2015, 03:26 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
If you don't know for sure what it is, why not call it what we all know it is - a mystery motor? (IMG:style_emoticons/default/confused24.gif)
chad newton |
Jul 30 2015, 03:31 PM
Lol, I will change it. Frankenmotor- of unknown origin.
euro911 |
Jul 30 2015, 05:55 PM
(IMG:style_emoticons/default/thumb3d.gif)
Since our cars are so old and just the nature of the beasts in general, many of our cars don't even have their original motors. Over the years, many have been rebuilt (some, multiple times), and unless the build documents followed those motors, you could have a 2.xL in a 1.7L bus case and not know it unless you open it up (IMG:style_emoticons/default/confused24.gif) I had what appeared to be a 1.8L motor that came out of a 914 I acquired a long time ago. It had a rebuild tag riveted over the factory stamped number, so I didn't even know what case it was, let alone what was inside it - so I listed it as a 'Mystery Motor'. Turned out, it was a 1.8L bus motor ... |
Lo-Fi Version | Time is now: 28th March 2024 - 02:21 PM |
