shifty issues |
shifty issues |
arsprod |
Jul 31 2015, 09:25 AM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
I need some transmission advice for my 74 2.0. When cold the car shifts nicely, i.e. goes into gear just fine. As it heats up it starts to grind going into first at a stop and I notice it's a little tougher to get into other gears. With a little pressure it always goes.
I thought it was syncros in 1st and 2nd because if I double clutch while moving it goes in nicely. But then I discovered it goes in nicely without the dbl just by moving forward. If this was a more modern car I'd suspect clutch slave or master cylinder, at least that's what it feels like - like the when hot the clutch isn't fully disengaging. I've adjusted the cable because when I got the car it had almost no free play (so I added some). Thoughts? |
JawjaPorsche |
Jul 31 2015, 09:37 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Try tightening the cable just a little more. Heat makes everything expand a little including your cable.
Also check cable and make sure it looks good. Might be ready to break. Believe me, they break at the worst times. I carry a spare in my rear trunk. |
arsprod |
Jul 31 2015, 09:47 AM
Try tightening the cable just a little more. Heat makes everything expand a little including your cable. Also check cable and make sure it looks good. Might be ready to break. Believe me, they break at the worst times. I carry a spare in my rear trunk. I wonder how you know that?! Will do, thanks |
JawjaPorsche |
Jul 31 2015, 09:53 AM
Try tightening the cable just a little more. Heat makes everything expand a little including your cable. Also check cable and make sure it looks good. Might be ready to break. Believe me, they break at the worst times. I carry a spare in my rear trunk. I wonder how you know that?! Will do, thanks I have own my 914 since new. Believe me, experience is the best teacher. Also a trick is to place into second before going to first. Helps prevent grinding. |
arsprod |
Sep 1 2015, 08:02 PM
Try tightening the cable just a little more. Heat makes everything expand a little including your cable. Also check cable and make sure it looks good. Might be ready to break. Believe me, they break at the worst times. I carry a spare in my rear trunk. I wonder how you know that?! Will do, thanks I have own my 914 since new. Believe me, experience is the best teacher. Also a trick is to place into second before going to first. Helps prevent grinding. Finally replaced the clutch cable this weekend - holy frijoles what a difference! And I bought 2, spare's in the trunk!! |
euro911 |
Sep 1 2015, 08:18 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,846 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I just posted about this the other day:
... you might want to order some spare cone screws for your mobile go-bag. You're stranded if you lose one in the field (IMG:style_emoticons/default/idea.gif) Another goodie that should be in everybody's go-bag is one of those little clutch cable clevis thingies and a couple 11mm nuts ... already attached to a spare clutch cable (IMG:style_emoticons/default/shades.gif) |
arsprod |
Sep 1 2015, 08:23 PM
I just posted about this the other day: ... you might want to order some spare cone screws for your mobile go-bag. You're stranded if you lose one in the field (IMG:style_emoticons/default/idea.gif) Another goodie that should be in everybody's go-bag is one of those little clutch cable clevis thingies and a couple 11mm nuts ... already attached to a spare clutch cable (IMG:style_emoticons/default/shades.gif) I'm psychic - bought extra one of those too and the nuts! |
arsprod |
Sep 1 2015, 08:29 PM
... and the gabelkorpf, clevis pin, and rubber boot. Pretty much everything listed in the diagram - and since the pieces I took off are still OK (except cable) I'm ready for a cable catastrophe!
euro911 |
Sep 1 2015, 08:38 PM
Lo-Fi Version | Time is now: 29th April 2024 - 04:30 AM |
