Door Panel Cup Bushing, Is there a generic source? |
Kansas 914 |
Aug 1 2015, 12:20 PM
I checked 914Rubber first and didn't see them. Probably because they are available just at $3.30 each (I need 18 of them) it kills me to buy OEM.
http://www.stoddard.com/999-591-311-40.html Has anyone found a Dorman part number or similar? Thanks in advance. |
Harpo |
Aug 1 2015, 12:33 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
What is it?
David |
jcd914 |
Aug 1 2015, 12:50 PM
They are plastic cups/sockets that go into holes in the door and the retaining clips on the door panel snap into them.
You could look from some GM style door panel clips that push into the holes in the door without any cup or socket. Personally I hate the GM style since they all seem to stay attached to the door and pull out of the door panel but they are cheap. Jim GM Clips |
Kansas 914 |
Aug 1 2015, 01:09 PM
Kansas 914 |
Aug 1 2015, 01:12 PM
They are plastic cups/sockets that go into holes in the door and the retaining clips on the door panel snap into them. You could look from some GM style door panel clips that push into the holes in the door without any cup or socket. Personally I hate the GM style since they all seem to stay attached to the door and pull out of the door panel but they are cheap. Jim GM Clips Thanks - these just might work - cheers! |
Kansas 914 |
Aug 1 2015, 01:41 PM
Upon further research 914Rubber does sell what I need.
When I first looked I was looking for the cup bushing but like referenced above Mark has the clip to do double duty. Thanks! http://shop.914rubber.com/Porsche-914-Door...lips-914DPC.htm |
zambezi |
Aug 1 2015, 01:43 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
VW uses a rubber version for their late model door panels. Not sure if they are the same size though.
http://www.jbugs.com/product/113857219A-56...ory_Code=104233 |
Kansas 914 |
Aug 1 2015, 02:09 PM
VW uses a rubber version for their late model door panels. Not sure if they are the same size though. http://www.jbugs.com/product/113857219A-56...ory_Code=104233 Thanks - those are nice! |
rhodyguy |
Aug 1 2015, 04:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Do you think they fit for the belt line trim push in's at the bottom of the sail panel?
zambezi |
Aug 1 2015, 06:58 PM
I would not think so because those holes are small. The holes for the door panel bushes are much larger (1/4 inch or more).
Lo-Fi Version | Time is now: 21st May 2024 - 09:09 AM |
