Original 914/6 front egine mount ? |
porschetub |
Aug 3 2015, 01:56 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
The top plate that sits on the rubber mount in my car has been nicely reproduced by the PO and then i'am on the Mittlemotor site and see there should be one on the bottom also....is this correct (IMG:style_emoticons/default/confused24.gif) ? My mount is a NOS original and if I have to fabricate on its not a real hassle just need to know, thanks. |
gms |
Aug 3 2015, 12:28 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
The top plate that sits on the rubber mount in my car has been nicely reproduced by the PO and then i'am on the Mittlemotor site and see there should be one on the bottom also....is this correct (IMG:style_emoticons/default/confused24.gif) ? My mount is a NOS original and if I have to fabricate on its not a real hassle just need to know, thanks. Yes there is a top and bottom steel piece as shown in the MM photo |
porschetub |
Aug 12 2015, 03:00 AM
The top plate that sits on the rubber mount in my car has been nicely reproduced by the PO and then i'am on the Mittlemotor site and see there should be one on the bottom also....is this correct (IMG:style_emoticons/default/confused24.gif) ? My mount is a NOS original and if I have to fabricate on its not a real hassle just need to know, thanks. Yes there is a top and bottom steel piece as shown in the MM photo Thanks,crawled under the car today and found the bottom plate stuck the the rubber on the mount....really stoked,my top mount is fabricated and the one I found is an original part ....one less job to do. |
Lo-Fi Version | Time is now: 21st May 2024 - 12:46 PM |
