Finishing A 914-6 GT Conversion Project, Great Start, But The Devil Is In The Details! |
Lucky9146 |
Aug 3 2015, 10:29 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,605 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Bought This car in Nov 2013 and unfortunately it had to sit in my trailer until May of this year to get started on it. The picture is how the car looked the way I got it and how it came out of the trailer. Factory P/N steel flares, nice paint job, a not installed 3.0 close to ready to install, Oh, and an in process conversion. Just some cleaning and put it together and yes a lot of learning/ research. Because (a) I have never owned a 914. (b) never done an engine conversion (built a few). © never picked up where someone left off (you know how its easier to put something back together when you take it apart).
I got the "bug" from a friend who took me up the Ortega Hwy in his 6 conversion and I was hooked. I decided to share my experiences with the "world" and hopefully along the way gain some insight. I have met some great 914 folks so far at swap meets and parts houses and everyone has been quite helpful. I will tell more of the story of what came with the car and what I have done so far as the days go by. Check in once in a while. Attached thumbnail(s) |
Lucky9146 |
Aug 9 2015, 01:37 PM
The "elephant in the room" continues by adding to the wiring "opportunity" with the concept of an aux fuse box furnished by the PO to handle the new electric fuel pump, and oil cooler fans as well as whatever else. PO had some great concepts which I agree with but looking for ideas on best location to put it aux fuse box and how to wire it in for my application. Kit form with all the afore mentioned is a lot!
Along with that is the the PO idea of converting to modern day fuses with a furnished brand new fuse panel. Thinking I need to just get it running first with old fuse panel and not add any more complexity to the issue. This is JWest clone made by Engman I believe. Pro's Con's suggestions are welcome. Attached thumbnail(s) |
porschetub |
Aug 12 2015, 02:05 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
The "elephant in the room" continues by adding to the wiring "opportunity" with the concept of an aux fuse box furnished by the PO to handle the new electric fuel pump, and oil cooler fans as well as whatever else. PO had some great concepts which I agree with but looking for ideas on best location to put it aux fuse box and how to wire it in for my application. Kit form with all the afore mentioned is a lot! Along with that is the the PO idea of converting to modern day fuses with a furnished brand new fuse panel. Thinking I need to just get it running first with old fuse panel and not add any more complexity to the issue. This is JWest clone made by Engman I believe. Pro's Con's suggestions are welcome. Since you have the fuseboard put it in ,they seem to get good press,however I would leave it till later as you suggested. Did you find your other indicator switch lamp wire?my missing one was tucked down the far left hand side near the headlight switch wiring,I think it was a black/green or similar this one is for the RH side. Have you a wire for your oil pressure gauge? I foolishly run new wiring into the engine space and forgot this one....bugger. In regards to your aux fuse box,i think they are a good idea,I ran a new 30amp rated cable for future amp and others devices and have a nice little 4 fuse block I intent to tuck up under the dash. |
Lo-Fi Version | Time is now: 25th April 2024 - 02:48 AM |
