| boxsterfan |
Aug 4 2015, 09:25 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Suppose a crazy person was thinking of A/C in their 914. Could such a crazy person run condensors in series behind the fog light grills?
Basically, the refrigerant (R134) would come from the compressor all the way up to the right front under the headlight, go through a condensor, come out of that condensor across the front of trunk, into a second condensor under the left head light area, and then back out to a receiver/dryer and through the rest of the system. Obviously, there are some cuts you need to make in the front area behind the fog light grills, the condensors have to be small enough to fit under the headlights when close and for good enough air flow you have to have cut holes in the front wheel well behind the condensors. I know someone on this board mounted some oil coolers in these locations (can't find the thread). 914 A/C reference from http://www.914world.com/bbs2/index.php?sho...=192917&hl= (thanks dlee6204). |
boxsterfan Question on AC condensors Aug 4 2015, 09:25 PM
Mike Bellis If you could make it work, put two in parallel. Th... Aug 4 2015, 09:47 PM
boxsterfan I was thinking I would run parallel flow condensor... Aug 4 2015, 09:57 PM
ThePaintedMan But how would you ever be able to put fans on them... Aug 5 2015, 07:03 AM
76-914 Why? Saving trunk space? Are you H20 or air cooled... Aug 5 2015, 07:41 AM
boxsterfan
Why? Saving trunk space? Are you H20 or air coole... Aug 5 2015, 12:23 PM
stugray
I know someone on this board mounted some oil co... Aug 5 2015, 08:02 AM
Dave_Darling You can run condensors in series. The 911s did th... Aug 5 2015, 09:20 AM
boxsterfan
You can run condensors in series. The 911s did t... Aug 5 2015, 12:25 PM
Mike Bellis
Running them in parallel would seem, to me, to ra... Aug 5 2015, 06:23 PM
76-914
Running them in parallel would seem, to me, to r... Aug 5 2015, 06:55 PM
Dave_Darling There were differences, though. Both condensers o... Aug 5 2015, 03:12 PM
Spoke Griffiths.com does this for the 911. It's call... Aug 5 2015, 04:40 PM
Chris914n6 The question is can you find a pair of 11x13 conde... Aug 5 2015, 07:56 PM
boxsterfan
The question is can you find a pair of 11x13 cond... Aug 6 2015, 01:32 PM
914_teener
The question is can you find a pair of 11x13 con... Aug 6 2015, 05:23 PM
stugray I chose to put my oil coolers in series because I ... Aug 6 2015, 05:48 PM
914_teener [quote name='stugray' date='Aug 6 2015... Aug 6 2015, 07:24 PM
boxsterfan
I chose to put my oil coolers in series because I... Aug 7 2015, 02:43 PM
stugray
Stugray, how did the oil coolers end up working f... Aug 7 2015, 04:46 PM
914_teener .....I quess my statement needs context. There is... Aug 6 2015, 09:28 PM
Dave_Darling What do you mean "re-heat on the coils"?... Aug 7 2015, 09:39 AM
914_teener
What do you mean "re-heat on the coils... Aug 7 2015, 04:39 PM
Chris914n6
Has to do with the psych curve Dave:
https://en.... Aug 7 2015, 06:45 PM
maf914
What do you mean "re-heat on the coils... Aug 12 2015, 07:04 AM
914_teener
[quote name='914_teener' post='2220293' date='Aug... Aug 12 2015, 09:27 AM
jcd914 I don't think the loss in efficiency due to th... Aug 7 2015, 10:02 AM
914_teener
I don't think the loss in efficiency due to t... Aug 7 2015, 04:52 PM
boxsterfan
I thought the question was whether or not the si... Aug 7 2015, 08:55 PM
stugray
Stugray, did you put fans on your oil coolers up... Aug 7 2015, 11:47 PM
boxsterfan I was reading about compressor mounting in another... Aug 8 2015, 12:18 PM
GeorgeRud The electric compressors require quite a high ampe... Aug 10 2015, 09:32 PM
stugray Yes:
http://www.jegs.com/p/JEGS-Performance-Pro..... Aug 10 2015, 10:05 PM
boxsterfan Wow pricey!! http://www.jegs.com/i/JEGS-P... Aug 10 2015, 10:38 PM
Chris914n6 Nissan Leaf $250ish
I don't have the for... Aug 11 2015, 12:28 AM
boxsterfan
Nissan Leaf $250ish
I don't have the fo... Aug 11 2015, 01:36 PM
jcd914 The Leaf 's electric AC compressor does NOT op... Aug 11 2015, 06:12 PM
boxsterfan
The Leaf 's electric AC compressor does NOT o... Aug 11 2015, 10:38 PM
jcd914
The Leaf 's electric AC compressor does NOT ... Aug 11 2015, 11:36 PM
maf914 Wow! The Nissan Leaf unit is actually a heat ... Aug 12 2015, 06:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:15 PM |
