Warped rotor?, Have now confirmed it's warped. |
john77 |
Aug 8 2015, 03:28 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that.
With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) |
porschetub |
Aug 8 2015, 03:44 PM
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that. With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) Take the caliper off and disconnent the axle and check the feel of the bearing ,AX puts a lot of strain on them,if thats ok get the rotors resurfaced. |
john77 |
Aug 8 2015, 04:16 PM
[/quote]
Take the caliper off and disconnent the axle and check the feel of the bearing ,AX puts a lot of strain on them,if thats ok get the rotors resurfaced. [/quote] Will do. I must have done 6 events tops since I had them done - they should last longer than that, right? Right now, with the calipers on, there's no play in them whatsoever. |
PanelBilly |
Aug 8 2015, 04:19 PM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
and I have extra axles/cv s in the classifieds if you need them
Spoke |
Aug 8 2015, 04:39 PM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
stugray |
Aug 8 2015, 05:05 PM
If the nut is not tighetened to full torque after the new bearings, it can ruin the new bearings.
Or if the car is moved on the new bearings prior to having the nut torqued.. |
porschetub |
[quote name='john77' date='Aug 9 2015, 10:16 AM' post='2220716']
[/quote] Take the caliper off and disconnent the axle and check the feel of the bearing ,AX puts a lot of strain on them,if thats ok get the rotors resurfaced. [/quote] Will do. I must have done 6 events tops since I had them done - they should last longer than that, right? Right now, with the calipers on, there's no play in them whatsoever. [/quote] Thats not a lot of time on the bearing for sure,certainly worth checking to start with . The rotors need only the smallest amount of ''runout '' to cause issues,they don't always wear evenly. |
zambezi |
Aug 8 2015, 05:38 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Are you running the 911 parking brake shoes. If so it's possible something in there is rubbing or out of wack.
Aug 8 2015, 05:54 PM
Pull the pads out and see if the noise continues. If so, inspect where the rotor goes through the caliper. Might be the edge of the rotor rubbing on the bridge of the caliper; this happens when you use Six rotors (solid) with -4 calipers. Might also be happening with your mix of parts.
--DD |
porschetub |
Aug 8 2015, 06:17 PM
If the nut is not tighetened to full torque after the new bearings, it can ruin the new bearings. Or if the car is moved on the new bearings prior to having the nut torqued.. Exactly,had the same issue with my own car,scrapping noise went away when I torqued the nut up properly ,it wasn't really that loose maybe 180ft/lbs,took it up to torque (217 ft/lbs ?)and all was good. Also check the caliper is done up tight on the trailing arm. My car isn't running (IMG:style_emoticons/default/sad.gif) but I found this issue when pushing the engineless body (IMG:style_emoticons/default/smile.gif) . Another thing for the OP is check the surface between the rotor and the axle stub,have seen rust build-up cause run-out,my old Golf GTI had that issue,good luck. |
mgp4591 |
Aug 8 2015, 07:07 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I can see the wear pattern in your rotor from your picture- your rotor is warped. See the polished part on the outer face and then also the untouched part that is directly up from the rotor hat in your pic? That's the part that isn't making as much contact so it has less drag. If you've got a dial indicator (a very good idea anyway for checking not only rotor runout but suspension wear as well amongst other things) you'd see a difference as you spin the rotor. You may have a sticking piston or a piece of debris holding the pad against the rotor causing excess heat from constant contact causing your warpage problem. Another opinion- ask Mr. Shea, he's the expert.
john77 |
Aug 8 2015, 08:57 PM
Do you have a dial indicator gauge? This is very useful for measuring the run out of the rotor. With the wheel on, you would be able to tell if the bearing is bad. HF has one for $35. Thanks for all the suggestions. I have to pull the CV joints to replace the diff shaft seals (this is possible, right?) as my tranny is leaking like crazy since I changed the oil, so I guess this can become a 'while I'm in there' job. Spoke, I have no idea what this is, but I want one. What is it? Scratch that, I'll google it. |
Spoke |
Aug 8 2015, 09:17 PM
Spoke, I have no idea what this is, but I want one. What is it? Scratch that, I'll google it. I bought one like shown for my 1996 Audi A6 when I bent all 4 wheels on various potholes in PA and NJ. On one particular pothole on RT78 outside Newark not only did I bend a rim, it blew the tire out. It's basically a very sensitive ruler. Attach it to the vehicle and put the dial on the rotor or rim. Spin the wheel and watch the gauge. If no movement, the item is true. If the gauge jumps wildly then the item is out of round. Easy to see if your rotor is true. Found on my 914 front end with '73 911 front end the new rotor was not true. Had to file the attachment face of the rotor until I observed acceptable run out. |
Krieger |
Aug 9 2015, 08:19 AM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Pull the pads out and see if the noise continues. If so, inspect where the rotor goes through the caliper. Might be the edge of the rotor rubbing on the bridge of the caliper; this happens when you use Six rotors (solid) with -4 calipers. Might also be happening with your mix of parts. --DD (IMG:style_emoticons/default/agree.gif) I had this problem on one side, but not the other. Just loosed rotor and move a little. Check both top and bottom of rotor for clearance. I think I have about 3mm on each side. |
john77 |
Aug 9 2015, 07:35 PM
This afternoon, I removed the cv joints/axle (I was replacing the diff shaft seal so had to do this anyway) and the brake disc continued to stick. So I pulled the brake pads too and then it stopped. No scraping at all. So it's not touching the caliper. With the pads removed, there's no play in the bearings either.
I have a dial indicator gauge on order, but it seems like everything is pointing to the disc being warped. Assuming it is that, for now, should any machine shop be able correct it? I'm guessing there's minimum thickness it can be taken down to before it's junk and I'd need to buy a new disc, right? |
Aug 9 2015, 09:52 PM
The minimum thickness should be stamped on the edge of the rotor somewhere. Turning the rotor will probably help.
You may have uneven pad material deposition on the rotor. Not sure exactly how to deal with that, if scotch-brite or steel wool or sanding would be able to do it or not. Eric Shea may have more ideas; he knows the brakes on these cars very well. (Despite his and my disagreement elsewhere on the board! (IMG:style_emoticons/default/wink.gif) ) --DD |
john77 |
Aug 26 2015, 10:11 PM
My new dial indicator informs me the rotor is warped. I think the cause of it may be that the outer piston is sticking. An article on pelican about replacing brake pads said to push the piston back in with a wooden stick, but no matter how hard I press it the piston will not budge. Should it be sticking out of the caliper this far?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1440648714.1.jpg) |
stugray |
Aug 27 2015, 11:22 AM
Stupid question, but why cant I see a E-brake lever arm in the pic?
I dont see the cover for the outer adjuster screw either. Rears requires you to turn the adjuster screw to retract the pistons. From the limited pics those look like front calipers. |
RoadGlue |
Aug 27 2015, 12:23 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Stupid question, but why cant I see a E-brake lever arm in the pic? I dont see the cover for the outer adjuster screw either. Rears requires you to turn the adjuster screw to retract the pistons. From the limited pics those look like front calipers. Vented rotors too. Looks like 911 M-calipers (I think) with no e-brake as they're normally mounted on the front. Bring a rock. |
john77 |
Aug 27 2015, 12:27 PM
Stupid question, but why cant I see a E-brake lever arm in the pic? I dont see the cover for the outer adjuster screw either. Rears requires you to turn the adjuster screw to retract the pistons. From the limited pics those look like front calipers. They're rear 911 m-calipers, so no e-brake. Sorry, completely forgot I asked about the calipers in another thread, not this one. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1440700511.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1440700511.2.jpg) |
Lo-Fi Version | Time is now: 25th April 2024 - 10:12 AM |
