Warped rotor?, Have now confirmed it's warped. |
john77 |
Aug 8 2015, 03:28 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that.
With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) |
porschetub |
Aug 8 2015, 03:44 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that. With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) Take the caliper off and disconnent the axle and check the feel of the bearing ,AX puts a lot of strain on them,if thats ok get the rotors resurfaced. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:20 PM |
