Warped rotor?, Have now confirmed it's warped. |
john77 |
Aug 8 2015, 03:28 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that.
With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) |
Spoke |
Aug 8 2015, 04:39 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
john77 |
Aug 8 2015, 08:57 PM
Do you have a dial indicator gauge? This is very useful for measuring the run out of the rotor. With the wheel on, you would be able to tell if the bearing is bad. HF has one for $35. Thanks for all the suggestions. I have to pull the CV joints to replace the diff shaft seals (this is possible, right?) as my tranny is leaking like crazy since I changed the oil, so I guess this can become a 'while I'm in there' job. Spoke, I have no idea what this is, but I want one. What is it? Scratch that, I'll google it. |
Lo-Fi Version | Time is now: 24th May 2024 - 09:58 AM |
