Warped rotor?, Have now confirmed it's warped. |
john77 |
Aug 8 2015, 03:28 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that.
With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) |
john77 |
Aug 9 2015, 07:35 PM
This afternoon, I removed the cv joints/axle (I was replacing the diff shaft seal so had to do this anyway) and the brake disc continued to stick. So I pulled the brake pads too and then it stopped. No scraping at all. So it's not touching the caliper. With the pads removed, there's no play in the bearings either.
I have a dial indicator gauge on order, but it seems like everything is pointing to the disc being warped. Assuming it is that, for now, should any machine shop be able correct it? I'm guessing there's minimum thickness it can be taken down to before it's junk and I'd need to buy a new disc, right? |
Lo-Fi Version | Time is now: 18th May 2024 - 10:51 AM |
