1.7l starting issues, motor starts if I disconnect cyl 4 injector cable |
b.stirbu |
Aug 9 2015, 04:14 PM
1974 daily driver Group: Members Posts: 27 Joined: 14-June 15 From: Netherlands Member No.: 18,848 Region Association: Europe |
Dear 914ers,
I'm quite in a pickle with my 914 1.7. The engine sometimes starts sometimes not (usually after it started, ran 5-10 seconds and then stopped and I couldn't manage to start it again). Messing arround in the engine compartment I accidentally unplugged the cyl 4 fuel injector and surprise the engine started and idled low. Tried again one, two, three times and he started succesfully, but as soon as I plug back the cyl 4 injector cable does not want to start again... What's wrong here? (the injector not, because I've swapped 3 with 4 and I still had the same problem). According to the attached current flow cyl 4 injector is in series with the cold start valve and the thermoswitch for the cold start valve.. Am I looking at the right diagram? I also don't know where current track 102 comes from. Also very interesting is that I removed the injectors 3 and 4 and placed them in two cups to see if they work, and I could start the engine in two cylinders (although the cyl 4 injector plug was connected) Cheers, Bogdan Attached thumbnail(s) |
Dave_Darling |
Aug 18 2015, 07:37 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Usually a 3000 RPM idle is a large vacuum leak. As in, one of the hoses to the plenum fell off.
--DD |
Lo-Fi Version | Time is now: 18th May 2024 - 02:07 PM |
