1.7l starting issues, motor starts if I disconnect cyl 4 injector cable |
b.stirbu |
Aug 9 2015, 04:14 PM
1974 daily driver Group: Members Posts: 27 Joined: 14-June 15 From: Netherlands Member No.: 18,848 Region Association: Europe |
Dear 914ers,
I'm quite in a pickle with my 914 1.7. The engine sometimes starts sometimes not (usually after it started, ran 5-10 seconds and then stopped and I couldn't manage to start it again). Messing arround in the engine compartment I accidentally unplugged the cyl 4 fuel injector and surprise the engine started and idled low. Tried again one, two, three times and he started succesfully, but as soon as I plug back the cyl 4 injector cable does not want to start again... What's wrong here? (the injector not, because I've swapped 3 with 4 and I still had the same problem). According to the attached current flow cyl 4 injector is in series with the cold start valve and the thermoswitch for the cold start valve.. Am I looking at the right diagram? I also don't know where current track 102 comes from. Also very interesting is that I removed the injectors 3 and 4 and placed them in two cups to see if they work, and I could start the engine in two cylinders (although the cyl 4 injector plug was connected) Cheers, Bogdan Attached thumbnail(s) |
Dave_Darling |
Aug 29 2015, 09:48 AM
Double-check your injector grounds. They are paired, though I forget which two share a ground.
Trigger points are paired diagonally across the engine, so 1/4 and 2/3. So the trigger points aren't a likely suspect, unless the injector wires have been swapped on one side of the engine. (Not that hard to do, though. Hmm. The engine will still run OK with them swapped...) Grounds first, then trigger points. That would be what I checked. --DD |
Lo-Fi Version | Time is now: 25th May 2024 - 05:55 AM |
