Timing question, Using adjustable timing lite |
oildrips |
Aug 10 2015, 09:39 PM
Newbie Group: Members Posts: 21 Joined: 22-December 14 From: Calgary Member No.: 18,249 Region Association: Canada |
If I set the adjustable timing light to 27 degrees, remove and plug the vacuum lines and wind the engine above 3500, should the timing mark line up in the peep hole on the shroud? Am I on the right track?
Lo-Fi Version | Time is now: 17th May 2024 - 04:05 PM |
