A-Pillar Base, ...a fun picture dump! |
TargaToy |
Aug 15 2015, 06:33 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
TargaToy |
Aug 15 2015, 06:37 PM
cary |
Aug 15 2015, 07:41 PM
Nice recreation...................
trojanhorsepower |
Aug 15 2015, 08:39 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Man that looks good!
Andyrew |
Aug 15 2015, 09:09 PM
Good work!
plymouth37 |
Aug 15 2015, 11:07 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
Nice Work!
Krieger |
Aug 15 2015, 11:33 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
That looks really good!
Aug 16 2015, 07:17 AM
Nice job, you make it look simple
johannes |
Aug 16 2015, 07:57 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Great job!
arkitect |
Aug 16 2015, 08:10 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Good job....I like your car support, jack stands on top of a wood structure. (IMG:style_emoticons/default/biggrin.gif)
Dave |
majkos |
Aug 16 2015, 08:13 AM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
:worship:Nice, Very nice, indeed.
TargaToy |
Aug 16 2015, 12:11 PM
Good job....I like your car support, jack stands on top of a wood structure. (IMG:style_emoticons/default/biggrin.gif) Dave Thanks for noticing! If you feel any better about it, the jackstands are in their lowest positions. I also have straps clamping the car down to the wooden platform. The car was leveled using a laser and shimmed at the low corners. This is something I did so that I could easily get into the engine bay when I was redoing the hell hole and reinforcing both suspension consoles. Everybody asks me how I'm gonna get the car back down. (IMG:style_emoticons/default/dry.gif) |
Montreal914 |
Aug 16 2015, 01:01 PM
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Very nice work!
Will you inject any kind of rust protection in between all these various layers that you rebuilt or the inside of the box will stay as bare metal? |
TargaToy |
Aug 16 2015, 02:10 PM
Very nice work! Will you inject any kind of rust protection in between all these various layers that you rebuilt or the inside of the box will stay as bare metal? The inside of the long and the every space I had access to (including up inside the pillar) were Ospho'd and then primered or painted with Rustoleum rattle bomb. The only part that's still bare inside is the box I just installed (plus areas that burned off near the welds). There are two drain holes at the bottom in the factory location and I'm still considering the best way to get some stuff in there. |
Montreal914 |
Aug 16 2015, 02:31 PM
OK, this is similar to what I'm doing. I'm using epoxy primer, except that the areas where I know will get welded, I mask it of from the paint and then paint it with Weld through primer.
In hollow areas that not accessible, I was thinking of spraying the Eastwood stuff that comes in a can with a flexible wand. (IMG:style_emoticons/default/confused24.gif) How did you spay Ospho in the longs? Did you have any spray gun or wand? I was thinking of doing this via the oblong holes in the cabin. |
TargaToy |
Aug 16 2015, 03:01 PM
OK, this is similar to what I'm doing. I'm using epoxy primer, except that the areas where I know will get welded, I mask it of from the paint and then paint it with Weld through primer. In hollow areas that not accessible, I was thinking of spraying the Eastwood stuff that comes in a can with a flexible wand. (IMG:style_emoticons/default/confused24.gif) How did you spay Ospho in the longs? Did you have any spray gun or wand? I was thinking of doing this via the oblong holes in the cabin. I didn't really have to do any spraying. (IMG:style_emoticons/default/biggrin.gif) The longs were both wide open. For the rear suspension console part of the frame, I made a long brush with a coat hanger and Ospho'd the inside of it. Moving forward, anything I built or repaired, I also Ospho'd and then coated as best I could. When you have the car cut apart, you can look inside the channels and you're seeing a lot of bare steel. I was extremely paranoid when I was doing the driver's side of the car and I was trying to get POR-15 everywhere--but then I inevitably had to weld to the other side of the treated steel which burned the stuff off. I suppose the best way is to wait until done and get the spray treatment everywhere you can...but this car lasted as a daily driver for 30+ years before I started on it. I'm not losing sleep about my new metal rusting through soon from the back side. When done this car will see way less bad weather and hopefully NO road salt. Oh, and my oblong holes in the cabin are gone now. I have also installed an Engman stiffening kit as part of this build. |
zambezi |
Aug 16 2015, 06:48 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
No door braces?
TargaToy |
Aug 16 2015, 07:11 PM
VaccaRabite |
Aug 18 2015, 08:53 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If you are welding without the doors in place or the doors braced, you are risking your door gaps. You won't know till you try to put the doors back on either.
Zach |
jmitro |
Aug 18 2015, 09:16 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Wow, great job recreating the sheetmetal and repairing the rust damage.
question - was the new sheetmetal custom fabricated, or available as a part that can be ordered online? If fabricated, how did you bend it? Sheetmetal brake? |
Lo-Fi Version | Time is now: 16th May 2024 - 08:10 PM |
