> 901 VS 915 TRANSMISSION, 450 HP V8 901 OR 915
RUDEPEST
post Mar 1 2005, 02:56 PM
Post #41
I have a 73 914 with a 450 hp v8 and have went through 3 transmission and am in the process of putting a 915 in it with a wevo side sift kit installed but I was told that I need to change the gears to work and was hoping that someone out there could help with the proper gears so I don't have to spend money learning which gears work.
thanks,
Keith
RUDEPEST   901 VS 915 TRANSMISSION   Mar 1 2005, 02:56 PM
bd1308   that is the longest sentence i have ever seen   Mar 1 2005, 03:05 PM
Travis Neff   You need to flip the Ring and pinion around, aside...   Mar 1 2005, 03:12 PM
Aaron Cox   are you asking if you need taller gears that would...   Mar 1 2005, 03:17 PM
skline     Mar 1 2005, 03:21 PM
skline   So, I am thinking, if you run it upside down, you ...   Mar 1 2005, 03:29 PM
bondo   For 450 HP I'd say neither. You probably won...   Mar 1 2005, 03:30 PM
BIGKAT_83     Mar 1 2005, 03:33 PM
Aaron Cox     Mar 1 2005, 03:33 PM
RUDEPEST   thanks for the replies. I have already fliped the...   Mar 1 2005, 03:36 PM
phantom914     Mar 1 2005, 03:36 PM
skline   Ok, I get it now. This is a first for Aaron. Good ...   Mar 1 2005, 03:42 PM
RUDEPEST   The 901 trannys haven't broke but I can tell t...   Mar 1 2005, 03:42 PM
Type 4   To make a 901 last you need to swap out the inter...   Mar 1 2005, 03:58 PM
Travis Neff   If a 915 has a vent at the top like a 901, your ga...   Mar 1 2005, 04:20 PM
Aaron Cox     Mar 1 2005, 04:23 PM
Andyrew   Call Renegade hybrids... They have a solution for ...   Mar 1 2005, 05:02 PM
MattR   ...   Mar 1 2005, 05:07 PM
chunger   I hear there's a custom R&P set that is geared...   Mar 1 2005, 05:19 PM
sj914     Mar 1 2005, 05:42 PM
chunger   That makes sense. . . at the time I was looking s...   Mar 1 2005, 05:48 PM
Travis Neff   whats the ballpark on the R/P? a kilobuck?   Mar 1 2005, 05:58 PM
ewdysar   The 3.10 R&P is NLA. One sold just over a year ag...   Mar 1 2005, 06:22 PM
nine14cats   Check with Rod Simpson. I talked with him late la...   Mar 1 2005, 06:40 PM
airsix   <...   Mar 1 2005, 08:35 PM
Gary     Mar 1 2005, 08:39 PM
airsix     Mar 1 2005, 09:12 PM
jd74914   But, say a 901 lasts for 10,000 miles; then you bl...   Mar 1 2005, 09:31 PM
Andyrew   Whats the cost of a wevo 915? 5k?? More?? 901 tra...   Mar 1 2005, 09:41 PM
jd74914   You've got a valid point. ...   Mar 2 2005, 11:01 AM
Type 4   Jeff at Transaxle Eng. builds the Fortin gearbox f...   Mar 2 2005, 11:15 AM
jd74914     Mar 2 2005, 02:38 PM
neo914-6     Mar 2 2005, 07:33 PM
marks914   450 HP? Tell us about the engine, thats pretty po...   Mar 2 2005, 07:44 PM
redshift   For 17k, you get a 6 speed ZF, that won't brea...   Mar 2 2005, 07:46 PM
Brett W   http://www.quaife.co.uk/catalogue/page11.htm Nice...   Mar 2 2005, 11:02 PM
redshift   Chatting with a couple Pantera guys, when I was lo...   Mar 2 2005, 11:13 PM
Gary     Mar 2 2005, 11:16 PM
Brett W   Thanks for the info. Too bad the Pantera used a F...   Mar 2 2005, 11:18 PM
andys   New ZF's are available through RBT in Orange C...   Mar 2 2005, 11:28 PM
cdmcse   Is the 944 transaxle worth using? Some of the 951 ...   Mar 3 2005, 01:37 AM
BIGKAT_83     Mar 3 2005, 06:18 AM
Brett W   I am going to start out with a 901, just to meet a...   Mar 3 2005, 07:30 AM
Andyrew   The 951 trani is not set up to have a clutch in th...   Mar 3 2005, 09:07 AM
Brett W   I am not referring to the 951/944 gear box. I am ...   Mar 3 2005, 02:04 PM
Travis Neff   Brett, what are you doing for an engine to warrant...   Mar 3 2005, 02:12 PM
Brett W   It is a secret for now. When things get a little ...   Mar 3 2005, 02:18 PM
Brett W   heres a hint:   Mar 3 2005, 02:34 PM
Travis Neff   tractor equipment? You gonna have to notch your...   Mar 3 2005, 02:37 PM
bondo     Mar 3 2005, 02:37 PM
andys     Mar 3 2005, 02:41 PM
Brett W   Yeah I found a GT 40 forum and have been reading t...   Mar 3 2005, 02:59 PM
Andyrew   Brett, my post was in response to. http:/...   Mar 3 2005, 03:52 PM
Wild 6   I have the 915 gearbox w/Wevo sideshift and intern...   Mar 3 2005, 03:59 PM
Travis Neff   Wild 6, tell us more about your car   Mar 3 2005, 04:37 PM
Brett W   Sorry Andrew.
  Mar 3 2005, 10:44 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:49 AM
