Rocker Fasteners |
Rocker Fasteners |
kupcar |
Aug 16 2015, 06:56 AM
Member Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
I'm getting ready to mount my rocker panels and I was wondering what is the proper fastening hardware to do the job. I can't seem to find any pictures. Is it a simple phillips machine screw from the top with a washer and nut from below? What about the bottom? Thanks.
TheCabinetmaker |
Aug 16 2015, 07:09 AM
They were riveted on the top. There are plenty of cars that have sheet metal screws. There are new rivets available. I prefer screw's. They can easily be removed for a yearly cleaning behind.
The bottom uses an m6 screw like those in the engine tin. I use a standard m6 x 10 hex head bolt on bottom. |
Aug 16 2015, 07:28 AM
Custom Member Group: Members Posts: 24,565 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Black rivets are the OEM fastener.
I use stainless screws up top and at the bottom I put a 3/8 inch rubber spacer between the cover and the longitudinal to allow debris to fall out instead of getting packed in there. |
Shadowfax |
Aug 16 2015, 07:30 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
I have an extra set of pop rivets from 914rubber. Yours for the price of shipping if you want to go that route. PM me if interested.
EdwardBlume |
Aug 16 2015, 07:34 AM
rgalla9146 |
Aug 16 2015, 08:55 AM
Pictures of actual original hardware for reference.
On early cars with aluminum threshold covers the fasteners were natural color nylon "rivets" with a center pin that fixed them in place. Not reusable. But.... some fanatics have "harvested" originals from the outer rows by pushing out the center pin and then extracting the rivet. Later cars with black plastic thresholds got black plastic rivets Attached thumbnail(s) |
Tom_T |
Aug 16 2015, 12:02 PM
Black rivets are the OEM fastener. I use stainless screws up top and at the bottom I put a 3/8 inch rubber spacer between the cover and the longitudinal to allow debris to fall out instead of getting packed in there. Partly true.... Black rivets came in with the black plastic sill plates in 74 MY & were 74-76, before then they were white plastic rivets on the aluminum sill plates/rocker tops. (11/912/930 of the era also used them & the later version went to clear-ich plastic rivets, which Porsche & other suppliers still sell. The bottom used the "cheesehead" slotted screws, & IIRC it's in the size Curt mentioned. PS - I forgot the black rubber spacer & other washers, but rgalla has them pictured above (cheeshead screw is the one on top right btw). You can find the size & type of most fasteners in the 914 parts manuals, & if you don't have one you can download a pdf one from the Porsche website, under Classic section's Documents (for the latest version), & at Jeff Bowlsby's tech & factory docs sections for a bit earlier ones. http://bowlsby.net/914/Classic/ Great references to have on hand for these types of things! Once you have the OE fitment item(s), then you can decide on the mods like those suggested above, or stick as close to original if you're into originality corectness. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
kupcar |
Aug 17 2015, 09:03 PM
Fellas, Thanks for all the help. This board and it's members have been more than helpful in my restoration. Shadowfax, Thanks for the offer on the rivets. I think for the moment I will source some stainless screws. I have a feeling I'm going to have to remove and reinstall these things a few times.
Cuda911 |
Aug 17 2015, 09:43 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
I recommend ditching the cheeseheads for hex heads, so that you can get a socket onto them. The cheesey's can get extremely difficult to get loose.
euro911 |
Aug 18 2015, 01:04 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
The PO of my car installed aftermarket fiberglass rockers panels with aluminum rivets. I lost the passenger side rocker in a rain storm, but acquired another set. After inspecting the longs and repainting the replacement panels, also installed them with SS self-drilling screws top-side.
Because the OEM steel set, the first glass set and the replacement glass set all had different mounting hole locations, there are now three sets of holes in the sills. I thought it would be better to use the existing holes in the replacement rocker panels rather than trying to match up to the existing sill holes and ending up with more visible holes in the rocker panels. Does this make sense (IMG:style_emoticons/default/confused24.gif) |
914Next |
Aug 18 2015, 04:40 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
rgalla9146,
The topic of rivets seems to have been discussed a lot but just for the record, I'm not sure I've ever heard a definitive word on what stock fasteners were. My '73 rockers have never been removed and have the black thresholds with metal rivets...not plastic. |
JawjaPorsche |
Aug 18 2015, 05:59 AM
I agree about sheet metal screws. You can remove your rockers more often if you need to inspect. Also, I had to get ALL the screws started, top and bottom before tightening. You can't do that with rivets.
I used stainless steel screws from Home Depot. Here are the rubber spacers. http://www.914centralshop.com/Porsche-914-...-rubbersill.htm Attached thumbnail(s) |
era vulgaris |
Dec 9 2015, 09:36 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Lo-Fi Version | Time is now: 27th April 2024 - 08:54 AM |
