h4 headlights and Bulbs, Whatcha guys doing? |
TravisNeff |
Mar 1 2005, 04:15 PM
Another neato find on the 72 is a set of H4 headlamps. They are the US versions (DOT stamp), not the Euro ones.
Anyhow, what are you guys running for bulb wattages and US/Euro lenses? |
sj914 |
Mar 1 2005, 04:19 PM
I think I used to run 80/100 on mine.
Whats the difference between euro and DOT, besides it saying DOT approved? |
TravisNeff |
Mar 1 2005, 04:32 PM
US Spec lamps have a different beam pattern than the European ones.
Aaron Cox |
Mar 1 2005, 04:35 PM
fluted type lensed
MarkG |
Mar 1 2005, 04:38 PM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
I use Cibie' Z-beams (U.S. type, i.e. right side of road) in all my 7" headlight cars. 55w standard H4 bulbs.
sj914 |
Mar 1 2005, 04:39 PM
Fluted? you mean the lenses with the lines running vertically on them.
drgchapman |
Mar 1 2005, 04:40 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
80/100's. Great vision at night. Draws down the battery, so need beefed up alternator.
TravisNeff |
Mar 1 2005, 04:44 PM
I have to dig into that already, when I turn on the headlights I start getting the alt light. Replacing the positive and ground cables this weekend ought to help a little.
scruz914 |
Mar 1 2005, 05:02 PM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
Anyone experience problems with the standard wires when running the higher watt bulbs?
sj914 |
Mar 1 2005, 05:17 PM
I never had any battery or alt. problems when I ran with the 80/100 bulbs.
azbill |
Mar 1 2005, 05:26 PM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
I'm using DOT H4's - I like them
TravisNeff |
Mar 1 2005, 05:42 PM
What bulbs are you running Bill?
The wiring most probably needs to be upgraded with two relays and a biggun wire directly from the battery. I read today that if your wiring drops a volt or two your 100 watt bulbs are really only 80 watts. |
Aaron Cox |
Mar 1 2005, 06:19 PM
where did you buy them? and how much?
ejm |
Mar 1 2005, 07:00 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The bigger problem is the ignition and headlight switches...they will heat up trying to handle the load of upgraded lights. Relays will greatly extend the life of these parts. Anyone price a headlight switch lately? |
Joe Ricard |
Mar 1 2005, 07:20 PM
Euro H-4's with 55/65 W bulbs stock wiring. Great lights. 100 W driving lights on heavy wire with relay. Melts the bumpers off Hondas.
Mark Henry |
Mar 1 2005, 07:54 PM
euro H4's std bulbs and pilot lights.
Aaron Cox |
Mar 1 2005, 07:58 PM
where do you get them??
Series9 |
Mar 1 2005, 08:04 PM
Is mine Euro or US? I thought it was Euro, but I got these right after I got the car in '98 and now I can't remember.
TravisNeff |
Mar 1 2005, 08:53 PM
Look for an embossed, or I should say raised spot on the lens that says DOT, can't miss it. If it doesn't have it, you are gonna need off road knoby tires on that thing (euro spec off road use in US), heh.
redshift |
Mar 1 2005, 08:55 PM
It's real small....
look real close, with the brights on. M |
Lo-Fi Version | Time is now: 17th May 2024 - 05:23 PM |
