Oil Leak at Connector, Flex Oil Line |
Highland |
Aug 17 2015, 10:45 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I installed a dual pole VDO sender with the kit it came with and am leaking oil at the
female NPT connector joint. The female nut rotates independently of the tube. I'm not sure how that joint seals. Is there an o-ring in there that may have dried out since this is NOS? Would it be okay to cut the tube and replace with a barbed to 1/8" NPT female fitting? |
stugray |
Aug 17 2015, 10:52 AM
Just go get a Grease gun extension hose.
Same threads and will probably cost the same as a brass hose barb. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:55 PM |
