Redesigning the factory wiring harness..??, Removing the non-essential wires? |
Mueller |
Jun 9 2003, 12:30 AM
Since my car is down to just a few remaining parts, I got to looking at the wiring harness and how half (okay, that might be exagerating a little) of the wires are not needed, such as the seat belt relay harness section.
Has anyone rebuilt thier harness to optimize the amount of wires and how they are routed? |
JeffBowlsby |
Jun 9 2003, 07:12 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Thats an immense task Mike...
Mueller |
Jun 9 2003, 09:43 AM
What fun would it be if it was an easy task?? (IMG:style_emoticons/default/smile.gif)
914Timo |
Jun 9 2003, 09:59 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Yes, BTDT, at least nearly. I did all new wires to the tailigths and engine. The old ones were in very poor condition. I didn chance the wires under the dashboard. I connected the new wires to the old wire harness in front of the sifter. At the same time I removed some Sport-O-Matic wires and others I didn need any more.
Hell a kind of job..... If you need I should have some measurements from the original wire harness. I measured the length of every wire and draw a map to the paper. I have thougth many times I should draw them agen with AutoCad or something. |
MJHanna |
Jun 9 2003, 10:20 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
Just turn very thing on, and start cutting wires. If something goes off then just tape it back together. This is really quick way to reduce the amount of wires. (IMG:style_emoticons/default/smash.gif)
ChrisFoley |
Jun 9 2003, 07:36 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You might as well remove the whole thing from the car and strip off all the tape and plastic. Then, with the help of a Haynes Manual wiring diagram you can figure out all the wires you won't be needing by color code and remove them from the rest of the spaghetti. You might also find some bad wires or connectors that need to be replaced. When you wrap it back up it will fit back in much easier since there will be a lot less wires. Can't be much worse than removing the dash, right?
Jun 9 2003, 11:11 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Racer Chris @ Jun 9 2003, 06:36 PM) Can't be much worse than removing the dash, right? correct. i missed out on that opportunity, if i had to replace it again, i would stripp it off the un-needed wires (and leave some in for all those NEW gizmos i'll get in the engine compartment). point is, chances are, you will find quite a few wires you don't use, like the whole seat-cusion/seat-belt waring crap, the door switches for the interior light (i don't have a backpad anymore), sport-o-matic wires, heated rear window etc. and more .... Andy |
Jun 9 2003, 11:14 PM
the task does not look that intimidating anymore once you have it out of the car. actually, it's surprisingly small (IMG:style_emoticons/default/smile.gif)
(IMG:http://www.sirandy.com/pix/914/work/009.jpg) |
Lo-Fi Version | Time is now: 20th May 2024 - 02:22 AM |
