1972 1.7 not starting |
ctkellett |
Aug 27 2015, 10:22 AM
Newbie Group: Members Posts: 12 Joined: 18-February 15 From: PA Member No.: 18,450 Region Association: None |
I bought a stock running project car with a bad tail shift transmission. I pulled the motor and replaced the transmission with a freshly rebuilt side shift unit from 914 LTD.
After the reinstall I am not able to get the car running again. Things that I have double checked -Fuel Pump runs and primes when the ignition gets switched on at the key -confirmed spark at the coil and at the plug with motor cranks -can hear the injectors pump once while the fuel pump is priming and when you step on the gas pedal once. -confirm that the timing is set correctly, that the points are gapped correctly. - the car will run briefly on starter fluid. Any thoughts? Maybe and ECU issue? Where do the injectors get the signal to fire? Thanks! |
914itis |
Aug 27 2015, 10:30 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Injector grounds ?
Back of the engine towards the trunk . Follow the ECU harness. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:08 PM |
