SOlD rear Boge shocks and 100 LB lowering springs |
bdstone914 |
Aug 27 2015, 09:25 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
sold
I have a set of nearly new rear Boge shocks that came off of a parts car. I pulled them for the lower spring perches. I doubt the shocks have many miles on them as they are the black replacement shocks and hardly have any dirt on them. Complete with upper perches , bump stops and upper hardware. You will need lower perches. Off the same car is a pair of 100 LB aftermarket lowering springs in perfect condition. New shocks are about $122 each so I am asking $125 for the pair and $60 for the springs which are $100 new. Shipping at cost. Attached thumbnail(s) |
914_teener |
Aug 28 2015, 12:17 AM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I have a set of nearly new rear Boge shocks that came off of a parts car. I pulled them for the lower spring perches. I doubt the shocks have many miles on them as they are the black replacement shocks and hardly have any dirt on them. Complete with upper perches , bump stops and upper hardware. You will need lower perches. Off the same car is a pair of 100 LB aftermarket lowering springs in perfect condition. New shocks are about $122 each so I am asking $125 for the pair and $60 for the springs which are $100 new. Shipping at cost. Pictures to follow. Bruce...I'll take the springs if they won't lower my rear anymore than it is now. I have the Boge perches on my car now. I have no idea what spring rate that is on there now. Spose I can measure it. Call me tomorrow or PM me. |
gcrotvik |
Aug 28 2015, 06:47 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Second in line on the 100 LB aftermarket lowering springs in perfect condition.
bdstone914 |
Aug 28 2015, 07:14 AM
Hi Rob,
Don't know how low your car is now but is that due to sagging springs? Forgot of note that these are late springs. The difference is the diameter of the wire used to make the spring. Early are a smaller diameter (10mm vs 11mm I think) so you have to use the correct perches or the spring does not fit in correctly. I still have a set of 2.0L cylinders at the shop with your name on them. (IMG:style_emoticons/default/poke.gif) Will try to call you today. Bruce |
914_teener |
Aug 28 2015, 12:56 PM
Hi Rob, Don't know how low your car is now but is that due to sagging springs? Forgot of note that these are late springs. The difference is the diameter of the wire used to make the spring. Early are a smaller diameter (10mm vs 11mm I think) so you have to use the correct perches or the spring does not fit in correctly. I still have a set of 2.0L cylinders at the shop with your name on them. (IMG:style_emoticons/default/poke.gif) Will try to call you today. Bruce I still want the cylinders. I got sick the weekend I was gonna come by. PM me on the springs or call me. I don't what is on the car now but it seems like the springs are flat or sagging I suspect they are the originals. I'll measure the diameter today. Rob |
Old Yella |
Aug 28 2015, 10:55 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
Bruce
I'm interested in the shocks. How much to send them to Santa Monica Also, were the boge perches only on the later cars? I have the perches but will the springs off the crap Kyb's fit. |
bdstone914 |
Aug 29 2015, 06:33 AM
1. How much to send them to Santa Monica A. will send for $ 15 2 Also, were the boge perches only on the later cars? A. change was it 72 i think. Slip an open wrench (a spanner ) over the coil of the,spring to measure the diameter. 3. I have the perches but will the springs off the crap Kyb's fit. yes. i think all crap KYB shocks were for later or larger springs. The problem is trying to fit large springs on small perches. KYB perches are welded on. must be Boge. call me 951 536 74 seven ate. |
914_teener |
Aug 29 2015, 06:26 PM
I talked to Bruce...passing on the springs....not the direction I.m going.
bdstone914 |
Aug 29 2015, 08:03 PM
Sale pending on springs. Gcrotvik has option to buy on springs
Lo-Fi Version | Time is now: 27th April 2024 - 10:52 AM |
